HP 12c Calculator Logo
Posted on Jan 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
One of the keys on my 12c calculator keeps "sticking" so the number often fails to appear on screen. Any advice please.
basemnt5
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 11, 2015
basemnt5
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4035
Points
10
For the record - these older calculators are made to be taken apart, maintenanced and fixed. Unlike modern broken obsolescence machines. I love that people actually have the time to post an answer to a fix that says "I have no idea how to fix - buy a new one."
I have a Canon MP250 and had the same problem with keys sticking. I looked on the back of the machine and there was only 2 screws to take off and even if you removed the screws the back does not come off. So I started looking at the front and the keys - and therein lies the solution.
Each of the keys pops off with a flathead screwdriver when you lift on the left side of each key. I recommend only taking 5 or 6 off at a time. Clean with q-tips and alcohol both on the base of the machine and the actual keys. Spray with canned air to remove any other debris. Then reattach - snap each key back on - they only go on in the correct direction. After you have reattached the keys then test the machine. I had an extra problem with the PLUS + key - it still was sticking after the cleaning. So I stared at the base under the PLUS + key and saw 2 small metal pins that needed to be moved to the left with a flathead before you reattached the key. Once that was on correctly everything worked like brand new.
k24674
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • HP Master 8,093 Answers
  • Posted on Jan 30, 2010
k24674
HP Master
Level 3:
Answers
8093
Questions
0
Helped
4671829
Points
21595
Here is a link to one of my earlier posts where I show how to test proper operation of the calculator. I invite you to read it.
Cpt button
There isn't one. Unlike calculators from other makers, the 12C knows whether you've just input a number or not. Simply press the desired item without entering a number to calculate it.
For example, if the book says to press CPT then PMT to compute the payment, simply press the PMT key on the 12C.
Cpt button
3answers
Sticking/Under responsive zero key on an HP12c!! Is it trash?
It could be some dirt or grit in the keyboard, which a blast or two of compressed air might clear out. It could be a worn dome on the inside of the keyboard.
If you want to have it repaired, there's FixThatCalc, though they're currently not taking new orders. There also have been several threads on opening and cleaning Voyager series keyboards at the Museum of HP Calculators. Here's one article on opening a Voyager.
Cpt button 12c calculator
Unlike TI calculators, the HP 12c doesn't have or need a CPT button. It knows whether you've made a numeric entry or not. To calculate N, I, PV, FV, or PMT, simply press the appropriate key without entering a number.
HP12c seems to not have enough room for numbers BEFORE the decimal point. I try to enter the number "85" and all that will show up is the 8.000000000
Initial Setup
One adjustment is important before we get started. By default the 12C displays only two decimal places. This is not enough. Personally, I like to see five decimal places, but you may prefer some other number. To change the display, press "F" and then the number of decimal places you wish to display. I would press "F 5 " to display 5 decimal places. That's it, the calculator is ready to go.
You need to hold the "F" key.---------
    1. Press and release the gold PREFIX key (f).
    2. Press the number key for the desired number of decimal places (0 through 9).
------------ Click this link below and follow the procedure:--- http://howtobyme.blogspot.com/2011/07/hp-12c-calculator-help.html
----------- This should help.Thanks.Helpmech.
2helpful
How do I get the numbers to appear normal. They are showing as expontential figures i.e. 1.6859 04?
To switch out of scientific notation and get back to fixed decimal notation, press the f key followed by the number of digits you want to the right of the decimal point. For example, to get the 12C to show dollars and cents, press f 2.
My HP 15C calculator recently developed a problem with the number pad being unresponsive. Calculator appears to pass the self test, however, the key pad test does not work at all. Suggestions for repair?
If the keyboard test fails the calculator should be sent for repairs. One shop in Pennsylvania repairs most models, except the newer ones. The URL is www.fixthatcalc.com. Best of luck!
Has new battery and wont turn on
Hello, You can try to perform the self-test. Procedure is as follows. To perform the self test on units with two batteries:
  1. Turn the calculator off.
  2. Press and hold the c01788482.jpg and c01774569.jpg keys; keep both keys held down for the next step.
  3. Press the c01788481.jpg key so the c01788483.jpg and c01788481.jpg keys are held down simultaneously.
  4. Release the c01788481.jpg key.
  5. Release the c01788482.jpg key, followed by the c01774569.jpg key. The main test screen displays the following: '1.L 2.C 3.H'.
    • Press c01788484.jpg to perform the LCD test (all LCD segments will be turned on). Press any key to exit.
    • Press c01788485.jpg to perform the checksum test and see the copyright messages. Press any key to go from one screen to the next until the main test screen, '1.L 2.C 3.H', is displayed again.
    • Press c01788486.jpg to perform the keyboard test. Press EVERY key on the keyboard until all the keys have been pressed at least once. The screen will progressively turn off with each key press. Once all the keys have been pressed and the screen is clear, press any key to return to the test screen.
Press c01788481.jpg to exit the test system. This will also turn the calculator off. If the calculator detects an error at any point, it will display an error message. For the HP 12c financial calculators with one battery, to perform the LCD self test:
  2. Press and hold the c01788480.jpg key, and simultaneously press and hold the c01788481.jpg key.
  3. Release c01788481.jpg then c01788480.jpg .
  4. After a few moments, all elements of the screen should be displayed. Press any key to exit.
1helpful
I can't tur in on T1-83 Plus
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on at all. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Wrong calculation of mortgage payment
Check to see if the word "BEGIN" appears on your screen. If so, you are calculating the payment on an "annuity due" basis, that is, the first payment is made on day one, and each period thereafter, rather than the first payment being due at the end of the first (30 days usually) period. To fix this, press the blue "g" button, and then press the number "8" (notice the word "end" printed on that key in blue ink). This should return you to the normal (first payment due at the end of the period) option.
k24674
Grand Canyon Tech
Grand Canyon Tech
