If your Maytag MDE4658AYW electric dryer is running hot on all settings, even on air fluff, it is likely that the heating element is not working properly. Make sure that the heating element is securely connected to the dryer and that the power switch is in the "on" position. If the problem persists, you may need to replace the heating element or contact the manufacturer for assistance.
I have the same problem with mine. There isn't a fluff filter that you can get to easily. When the engineer came to fix something else he showed me this big tube thing inside the machine that had the inside coated with fluff. The machine wasn't very old and I only use the dryer for underwear (apparently towels make it much worse). So ... you'll have to get someone to dismantle the machine to get to the fluff. I was wondering if it is covered by the guarantee because it is ruining my washing.
Your duct work is probably clogged with the fluff, which will not allow the air to flow though like it should. When that happens, the heat builds up on the cabinet and the heat sensor shuts down the heat. Its an easy fix, it this is the case. Just remove the duct from the dryer, clean it out, clean out the fluff from the dryer duct connection, then go outside and inspect the outside dryer vent for clogs. Make sure the flapper is working on the outside vent as well. Good luck!
You don't say how much fluff is escaping, but some things to check are -
1) That the lint screen is fully seated into the top of the dryer vent 2) All the way to where it discharges the house, is clean and free of restriction 3) Check that the dryer door gasket and lint screen cover gasket's are in good condition and do not allow air leakage.
Make certain the flex duct leading from the back of the dryer is connected tightly to the dryer and the vent duct, and make sure the flex duct is not split or broken.
Try hooking it out with a long piece of fairly strong wire with a hook on the end.
It won't stop the dryer from working, but if it is vented , remove and clean the vent hose by running water through it, this will remove all traces of fluff, and make sure the outside is clear if it goes through a wall.
Plz rate my solution.
Thanks.
