Asko W6461 Front Load Washer Logo
Posted on Feb 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F3 error for my washes i always get an F3 error after (during the spin cycle) whats this error and how do i fix it?
  • vodkacran Feb 10, 2008
    do you know where i could find info about cleaning the draining system?
    ive tried to open the drain down on the left, and check but it still shows the error.
Timon Gr?nlund
Level 2:
  • Expert 126 Answers
  • Posted on Feb 07, 2008
Timon Gr?nlund
Expert
Level 2:
Answers
126
Questions
0
Helped
57493
Points
165
CHeck outlet filter, and draining system. Seems to be something that is stuck in the pump.
  • Timon Gr?nlund
    Timon Gr?nlund Feb 11, 2008
    The filter is behind the little door at the bottom of the front on the machine. Clean the filter, and look if there is anything that blocks the impellar on the pump.
3answers
Kenmore 80 series will spin when draining, but not agitate or spin during spin cycle.
Hello. I'm a little confused at the description of the problem. You indicated it, "will not agitate during wash cycle or spin during the spin cycle." But later in your description you indicated, "It will however, drain and spin after wash cycle and during the rinse cycle." I'm not sure if you description was an error but it sounds like you will need to replace the coupling which is part number 285753A.
2answers
The spin cycle is very noisy. What could be the problem?
hi robyn.
A washer making a loud noise during spin cycle can also be caused by a faulty drive pulley. The pulley is what the belt (if applicable to yourwasher) rides on to spin your washers tub. The pulley can be made of plastic or metal. It could be simply worn out or just loose.27 Jul 2015
How To Fix A Washing Machine Making Noise During The Spin Cycle ...
https://removeandreplace.com/.../washing-machine-making-noise-during-the-spin-cycle-...
or try this link might help you.
washing machine spin cycle is very loud Google Search
Spin cycle is not working error message F3
you have a blockage,also is there a plastic ball and ring in the sump hose.if yes take out and throw it away
1helpful
My Maytag will not run a complete cycle. Is there
mgissy
What is your machine model number? Is it a FAV6800A or FAV9800A TL?
If it’s a FAV6800A or FAV9800A TL do you error out in the Spin cycle of the wash cycle with an unbalance error code such as dC or uC? Is the wsh tub banging around during Spin Cycle of the Wash Cycle?
If so see this post Clutch Fix. I have a step by step maintenance/repair process for Clutch Pulley assembly issues related to the above error codes.
Post back if you have questions or concerns………Rich
WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
6helpful
1helpful
2answers
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Top Asko Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
