You can reset the MarkNet X2000 to factory defaults - which includes resetting the IP address to 0.0.0.0 like this: 1. Press and hold the Test button until all four lights stay lit simultaneously, then release the Test button. 2. When #3 and #4 lights light simultaneously, press and release #1 (the Menu button). 3. When #3 lights press and release #1 (the Menu button).
4. At this point the X2000 print server has been restored to the
factory default settings and should have an IP address of 0.0.0.0.
What model? Can you ping it? Does it show up in the control panel as available. have you reloaded the print drivers have you power off the machine then powered on. have you cleared all print jobs in the print que. Those it copy ok? Ethernet cable ok or using old serial? Can you print from a different computer. have loaded the IP address as static most copiers do not like DHPC where the server decide the IP address. Always use Static you tell the copier what IP address to use.
What model? Can you ping it? Does it show up in the control panel as available. have you reloaded the print drivers have you power off the machine then powered on. have you cleared all print jobs in the print que. Those it copy ok? Ethernet cable ok or using old serial? Can you print from a different computer. have loaded the IP address as static most copiers do not like DHPC where the server decide the IP address. Always use Static you tell the copier what IP address to use. Mite also check to make sure you have the right drivers for the machine.
http://publications.lexmark.com > mnpset_web
PDF
If your network is not using DHCP, you must manually assign an IP address. One of the easiest ways is to use the Print Server Setup. Utility on the drivers CD.
1. Clear your cookies and temporary internet files (AKA cache), exit from the browser, then restart the browser.
2. If you are a home user and do not pay for a static IP address, get a different dynamic IP address; do [Start] > [Run] > cmd > ipconfig {{write down the IP address, then disconnect from the Internet with}} ipconfig /release {{wait a few minutes and then reconnect with}} ipconfig / renew {{compare the new IP address to the old to make sure your IP address changed, then try again}}
If you are an office user, try someone else's PC which will have a different IP address.
You may have to remove the old Local Area Connection from windows, and resetup the network to use the new card. Bar that, if you remember your old IP address on your private network, you could setup the new Nic's IP address to the old IP address.
Yes. On the front panel menu, go to the I/O submenu and under that submenu you'll want the embedded jetdirect menu. This is where the network settings can be configured.
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel. On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
chances are you would need to RAM FILES, FLASH FILES, DEFRAG FILES....this is like resetting and crashing the terminal, starting all over again.
Try this, press F2 & F4 together you should be on GO VARIABLES, enter password 1 alpha alpha 66831 use the down arrow locate RAM FILES, CLEAR ALL GROUPS, CONFIRM, FLASH FILES, CLEAR ALL GROUPS, CONFIRM, then DEFRAG, ALL GROUPS, CONFIRM
Plug in your DSL or cable line (the one you are using) locate the DOWNLOAD, do a FULL
this should pickup your new IP address and make sure you are on COMM SERVER not on DIAL
(dial is only for analog phone line)
