I just bought these and put in batteries provided and plugged it all in but it doesn't seem to work. None of the lights on the transmitter have come on, and when I switch the headphones on, all I get is 6 beeps and static. Any help would be much appreciated...
There is help for this in the user manual. Possible solutions I would try:
1. Make sure your source sound (TV, amp etc) is up high enough - if the sound is too low the headphones won't detect a signal.
2. Try changing the channel (the switch on the bottom left of the cradle base) and pressing the "Tune" button on your headphones. Try all three positions, pressing "Tune" at least 3 times in each position.
3. Take out batteries & turn off base, leave for 30 secs, reassamble and try step 2 again.
Should all work ok. I've been using mine for over a year and they're great!
Thank you for your response. It turns out that my transmitter was faulty (I tried the solutions you mentioned but to no avail) so I was able to return it to the retailer. Much obliged to you anyway good sir =o)
Transmitter lights on my new RS 130 set do not light when plugged into a Sony STR-DG600 transmitter that works with other headphones. I tried removing batteries while unit is unplugged, and changing channels while pressing the tuner button. I need your help. Thanks
