MSI Wind U100-016US Laptop Logo
Anonymous Posted on Jan 09, 2010
There are little blue numbers on my keyboard and i'm wondering how you turn off when you hit fn?
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Jan 09, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2555180
Points
31058
The 'FN' key changes a "grid" of the keyboard alphabetic keys
to a numeric keypad "grid", when you hold 'FN' down and press the 'NUMERIC LOCK' (or 'NUM LOCK') key, and then release the 'FN' key.
Testimonial: "thanks"
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Keyboard numbers are jumbled
Above my scroll/# lock the lightbar is lit,and some letters produce #... i = 5 etc
Sounds like yo have the scroll lock or num lock turned on. If the scroll key is a colored key (the scroll lk lettering is blue) then you will have to Press and Hold the FN function key at the lower left portion of the keyboard then hit the scroll key to turn it off. When it is turned on if you press the letter i you get the number 5. If you press the letter O you get the number 6.
Notice that the numbers on the keys that have letters are a different color than the letters (blue most times). That means you have to Press and Hold the blue FN function key at the lower left portion of the keyboard then hit the key with the same color if you want the colored representation to happen.
Some laptops will use a Square Box instead of the blue colors on the keys. In that case you have to press and hold the key a the lower left portion of the keyboard that has the square box, then hit the key you want.
3helpful
2answers
2eyb6erd er6r
The number 2 is showing up on your keyboard because you have the Num Lk (Number Lock) key on and you are probably hitting the FN key then the K key so the little number 2 that is on the K key appears as what is typed. for example: On my keyboard there is a Big Letter K key and also on that key is a small number 2 which is blue. In order for me to get the number 2 when I type I have to have the Num Lk key on and then I have to Press and Hold the blue FN function key on the lower left of my keyboard then hit the K key and the number 2 is what gets typed.
1helpful
3answers
Unlock numeric key pad on lap top
your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
There is another option that is a little more intense - if interested let me know that laptop type you have.
2helpful
2answers
How do i turn off my blue keys on my inspirion keyboard
if the number lock on the keyboard is activated, then press Fn + Numlock to turn it off
6helpful
2answers
Key board issues
You have accidentaly turned on the number lock "numlock"
it is one of the keys on the top row FN + F11 I think
If this information was useful please click
5helpful
4answers
Fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
2answers
Emachine laptop Fn key locked
I think the only solution is to phisically remove the key from the keyboard - VERY gently, in order not to break or send flying the pieces to which the key is attached. The little rubber button underneath might be squished below those pieces.
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
