I means you are saving your pictures to the internal memory instead of the memory card. Move the pictures to the card and put them onto your computer. Once you have them out of internal memory, format the memory and select external storage in the setup menu.
Hi!
Some cameras have a limited internal memory. To make more space on your camera, you need to connect it to a computer to move the pictures in there, or to add a external memory space to your device like a memory card.
However, you should know that memory cards have different sizes and you need to check your camera to see what type of memory card accepts.
I hope this will help you!
Have a nice day!
*please don't forget to rate my services :)
Have you insert a memory card in it ? If we don't insert the memory card, pictures that have been taken will automatically saved in camera internal memory, and this memory usually have low capacity so we won't make many pictures because the memory will full in no time. The solution is insert proper memory card (kind and capacity). If you have insert the memory card the camera shows that notification, it means you need to transfer your pictures data in PC so you can delete them and make more space in your camera memory card.
It simply means that your phone's internal memory has less than 5 mb of free space and the camera require at least 5 mb of space to operate. So you have to free up a minimum of 5 mb from your internal memory.
Hope this will help....cheers:)
This camera has small internal memory like 32MB to store few pictures and shows no memory space message after storing these few picture files. You need to insert memory card in camera and go to menu and select Copy option to copy internal memory images into memory card then take out memory card from camera and delete internal memory pictures one by one or perform format memory to delete all of them at once.
OK, this message means that the internal storage capacity of the camera is full, hence you will need to copy the photos of your camera to make some space for new photos, or you will need to insert a memory card. The purpose of the memory card is to increase the storage capacity of the camera.
hope this can be of help. Please let me know if you need further assistance.
Hi. Actually you justneed to delete or transfer some pictures on the internal memory to your memory stick or you could remove first the memory stick and plugin you digital camera to your computer and copy all the pictures or videos on the internal memory of your digital camera.
This means that the internal memory of the camera is full. Apart from the external memory slot, camera's have this what you call internal memory. It is built-in to the unit itself.
What you want to do is to set the default storage to the external memory instead of the internal once.
On the Menu, navigate to image store and then choose AUTO.
Auto (default)—the camera uses the card if one is in the camera. If not, the camera uses internal memory. Internal Memory—the camera uses internal memory, even if a card is installed.
Also, you would want to set the camera resolution to a lower value to. The higher the pixel rate, the bigger space it eats up in your memory storage.
This error message means that there is no space remaining in the internal memory. Turn off the camera and insert a memory card, or transfer or delete pictures
This error message means that there is not enough space in the location you are copying to (internal memory or card). Delete pictures from the location you are copying to, or turn off the camera and insert a new memory card.
