Sewing Machines Logo
Posted on Jan 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Viking Classica 100 and the hook just
I have a Husqvarna Viking Classica 100 sewing machine and the hook just broke, the center shaft that the bobbin case snaps on to snapped. Where can I get a replacement? Also the part that holds the hook has a small peice broken from a bent needle. Should that be replaced also?
Thanks
  • dianne hemeier
    dianne hemeier Feb 14, 2018
    ok ican't get to change the size of stitch
deborahcha
Level 2:
Novelist:
  • Husqvarna Expert 371 Answers
  • Posted on Feb 11, 2010
deborahcha
Husqvarna Expert
Level 2:
Novelist:
Answers
371
Questions
0
Helped
147605
Points
481
Yes, these parts should be replaced. Original parts are only available from an authorized Husqvarna Viking Dealer. The service/repair is very intense and should be performed by a certified Husqvarna Viking service technician through the Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Husqvarna Viking Classica 100 sewing machine Service Manual please?
Question edited for clarity and correct order of make model.
Question moved for Cars and Trucks category.
Unfortunately there isn't one. Owner manual only. Service agents are factory trained, and have online resources, but generally they already know their way around inside all machines.
https://www.google.com/search?q=Husqvarna+Viking+Classica+100+service+manual
If it is stuck in reverse, there is help on Fixya from 2012.
I change light bulb in husqvarna classica 100?
if you don't have the accessory that looks like a short piece of rubber hose used to remove and reinstall the bulb, take the machine to an authorized Viking repair dealer and ask them to install a new bulb.
1helpful
Changing a presser foot on classica 100
Look at this page for a visual to help you determine the type of "shank" you have.
http://www.clotilde.com/pages/which_foot.html
2helpful
Viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
2answers
I am looking for a manual for a viking husqvarna
Call Husqvarna at: 1-800-474-6437. They may be able to get you a photo copy of the original owners manual.
How to thread my sewing machine? Husqvarna Classica 95
Suggest you contact an authorized Husqvarna Viking dealer. They can order you a user manual. Authorized dealers can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Brief description of probably how to thread from looking at a picture of a Classica 90 machine which should be similar -
Thread sits on spindle on backside. Pull thread straight across to upper left backside and fit in the metal guide. It should pull easily with only a little resistance. Pull thread forward across top toward you. Let thread fall between the metal disks (doesn't matter which one if more than one) and pull thread straight down. Pull thread slightly to the left to fit under a hook of some type and back up to fit through the large hook that moves up and down when the handwheel is turned. Come straight back down to needle and thread through eye of the needle. Just above the needle should be a thread guide (sideways hooking looking metal piece), slip the thread through it to hold thread close to needle. Hope this helps. Otherwise a local authorized Husqvarna Viking dealer will be glad to help you. Good luck.
2answers
Manual
I find a classica 100 on www.sewingmanuals.com. Would that be similar?
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
