Drain the transmission fluid & remove the filter.
Install a new filter & transmission gasket.
Noticed the amount of fluid coming out, then put in new fluid at that amount.
Open the engine hood.
Remove & get access to the MAP/air flash system, clean it out very well without breaking or bending anything.
SOURCE: Dodge 1500 service engine soon
Need to get A/C levels checked and might need more freon and go to the auto parts store and have them run an OBD2 scan on your truck. Than go to www.canobd2.com and put your vehicle and code in and see what that code is in reference to.
SOURCE: Need to find out what
Fig. Cylinder head torque sequence-4.7L engine
Install the cylinder heads. Use new gaskets and tighten the bolts, in sequence, as follows:
Hope this helps (remember to rate and comment this answer).
