Question about Symantec Norton Ghost 9.0 for PC
Hi When I boot up on WXP I get the system32 folder appearing other than that it boots ok I also tried to do a Ghost copy of my old hard drive to replace it with a bigger hard drice it got to 99% and it came up with and error message ea3905fe
    New Friend:
  • 90 Answers
This occurs when a cluster is listed as belonging to a file, but the volume bitmap does not list it as used. Unfortunately NDD nor CHKDSK can correct this cross link. You'll need to delete and rebuild the partition after backing up your data of course, but you may lose data during the copy if any data is on one of the bad clusters.
Posted on Jan 15, 2010
Testimonial: "Many thanks for that I had managed to fix the problem already by obtaining a full ghost copy of my hard drive with assistance from Norton."
  • 40 Answers
From a quick search, it looks like you need to do a chkdsk (check disk, a windows tool). easiest way to do it:
go to my computer >> right-click on your OS hard drive (C:, normally) >> go to properties >> click the tools tab >> under the Error-checking section, click Check Now >> select both check-boxes and click start
you should be prompted that you can't check the disk because it is in use, and that you can automatically scan it on the next reboot. agree and reboot.
hopefully that will fix you up!
Posted on Jan 19, 2010
6ya staff
SOURCE:
Dualbooting Win XP Pro on different drive
XP is dead. I recommend you make sure any critical data is backed up, and start saving/looking for a newer machine.
Jul 01, 2014 | Computers & Internet
Says windows root>\system32\hal.dll. is missing or corrupt, can't use laptop Please advise, regards Jason
some system on your windows has corrupted, it caused by a virus or bad disk
you need to restore your system to fix this issue
if your laptop build in windows xp and you have a restore disk just follow these steps
1. turn on your notebook
2.quickly press ctr and f11 simultaneously
3. click restore when "Dell PC restore" message appears
4.click confirm (it means you will lost all data in drive which contains your old operation system)
5.wait and click finish when the process of restore finish
if your laptop build in windows vista you can follow these steps
1. turn on your laptop
2. quickly press f8
3. when "Advance Boot Menu" message appears just click repair
4. select language and click next
5. log in and click ok
6. click dell factory restore and click next
7. click yes on the box "format hard drive and restore the system"
8. when the process finish click finish
if you don't have a restore disk build in your laptop you need a windows cd installer to reinstall your os
Jun 06, 2011 | Dell Inspiron 6000 Notebook
File: \Windows\system32\drivers\wdf01000.sys status: 0xc0000098 info
Boot up from the DVD drive with a windows bootup DVD, or boot up in recovery console, Ok, rename the file Wdf01000.sys to Wdf01000.old and copy new file from the Vista CD back to local drivers folder. then you will be back in business.
May 19, 2010 | Acer Aspire 3680 Laptop
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
Apr 10, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
My acer 5735 laptop sreen stays black at start up
First of all, go to advanced boot options, and see whether last known good configuration works or not
can you boot into safe mode? If so, try to do system restore, if that doesn't work as well, try to do a clean boot, followed by an advanced clean boot and a hardware clean boot.. these steps might help ..
clean boot : http://support.microsoft.com/kb/310353
advanced clean boot : http://support.microsoft.com/kb/316434
hardware clean boot :
Follow the steps below to perform hardware clean boot
1. Right click on My Computer -> Properties
2. Hardware Tab -> Device Manager
3. Right Click on Sound Card, Video Adapter, Network Adapter one by one and click disable
4. Reboot the computer. If the problem is fixed then you can enable the hardware devices one by one to find the exact device that cause the problem
If these steps don't solve the problem, unplug any external devices from your computer and see whether that resolves the problem .
If nothing works, try doing system restore from winre, if that doesn't work as well, you'd have to do that manually,
try these steps,
go to WinRE) open folder C:\Windows\System32\config
and rename these files:
BCD-TEMPLATE ->BCD-TEMPLATE.OLD
DEFAULT->DEFAULT.OLD
SAM ->SAM.OLD
SECURITY ->SECURITY.OLD
SOFTWARE ->SOFTWARE.OLD
SYSTEM ->SYSTEM.OLD
(don't change COMPONENTS file because system don't store any copy of this file,BCD-Template system will reconstruct automatically when you boot into WinRE)
Next navigate to C:\Windows\System32\config\RegBack folder and copy all items to C:\Windows\System32\config
Next boot into WinRE and try again restore system to previous checkpoint.
The last option would be to format your root drive and install the OS again..
Hope that helps, and good luck
Nov 23, 2009 | Acer Aspire 5735 Notebook
Hp paviliondv2050us wont start
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
Jul 21, 2009 | Computers & Internet
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
Describe your Acer Aspire One PC Notebook
first boot your computer with winxp recovery disk.
then ewnter in recovery console then type in command prompt "chkdsk /r"
then press "y" then it fix error on disk.
then check.
Jun 25, 2009 | Acer Aspire One PC Notebook
No WindowsXP, corrupt file windows\system32\config\system
Sad to say but alot of the computer manufacturers send Windows install/restore disks that are basically hardwired to the original hardware setup. The only real solution if you cannot install over your old setup would be to purchase the full version of the Windows o/s you want to install. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | EliteGroup ECS C19-A SLI C19XE & MCP51...
Transferring info from one hard drive to another
No that wont work.  :)
You will never be able to copy all the files from windows.
Here is my suggestion.
Their are several programs out their to help you accomplish a disk to disk copy. I personally use Norton Ghost. Action True image is another.
This particular program i have found extremely reliable.is Norton Ghost 2003. This is a hard drive cloning software that runs from dos.
When you are running windows, you cant copy by drag and drop, all the files. Windows just wont let you move the important files.
You could purchase norton ghost 2007. That software is designed to work from windows. You can install it and then clone the running drive onto the new fresh drive.
After you clone the drive, you can just set it to "active" and switch the boot order in the bios. Or just unplug the old drive.
I can assist you in getting a copy of norton ghost dos edition, and clone the drive. However it would require direct connection to your pc, and phone support to walk you threw it once your into dos.
Oct 11, 2007 | Computers & Internet
Symantec Norton Ghost 9.0 for PC Logo
70 people viewed this question
Top Symantec Computers & Internet Experts
Peter Dragonetti
Ekse
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
