My HE2T was making a horrendous sound during the spin cycle. It was
making a loud clacking sound and the machine was moving all over the
place.
There are two things to check. The first is that the feet
are on the floor and the machine is level. The second is a bit more
complex. Remove the three screws that hold the lower panel. Underneath
the drum on each of the four corners are suspension rods. One side is
attached to the drum and the other side is bolted to the bottom of the
washer. My bolts loosened up which allowed the suspension rods to clack
back up and down as the drum spun. You'll need to tighten those bolts
very tight and then give it another try.
Attached on the inside
of that cover is the troubleshooting guide. There is a manual
diagnostic mode and you can step it to the spin cycle so that you can
test the spin balance without having to run through a full cycle. Make
sure you have some clothes in there during the test.
Http://fixitnow.com/wp/2009/05/19/frigidaire-kenmore-front-loading-washer-knocks-and-shakes-during-high-speed-spin/
