I have a HP laserjet 4L printer (old) with a parallel port. i have a thinkpad x200 with USB ports i want to get a cable to convert from USB (out from the computer) to the printer (parallel).
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Not all USB adapters are the same, you need the one that is made for your printer, I would try a different adapter before going too deep, because when you plug it in your computer should see it even without drivers.
You mentioned parallel usb. The HP4L only has parallel. Make sure you specify LPT1 as the port you want. Try reinstalling the driver. It should be in the list of drivers.
