Switch on or off To switch on, press and hold the multifunction key for about 2 seconds. The headset beeps, and the green indicator light is displayed. The headset tries to connect to a paired phone. To switch off, press and hold the multifunction key for about 5 seconds. The headset beeps, and the red indicator light is briefly displayed.
Pair the headset 1. Ensure that your phone is on and the headset is off. 2. Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. If the pairing is successful, the headset appears in the phone menu where you can view the currently paired Bluetooth devices. When the headset is connected to your phone and is ready for use, the green indicator light flashes slowly
call at ur service provider and ask dem to send the settings it comes through a msg den just save those settings or open loopmobile.com search the settings and do as it says
i had the same problem. when i installed the usb driver i got that message too. but after this i installed pc studio 3 and with the phone explorer it worked for me.
CAN’T CONNECT 1. Displays when one handset is on a call and the other handset presses PHONE. 2. Displays when base power is off and PHONE is pressed. You’ll also hear a sad tone. 3. Displays when an out-of-range dial fails to connect. MAKE SURE THE HANDSETS ARE FULLY CHARGED. MAKE SURE BOTH ARE TURNED OFF, OR NOT IN THE TALK MODE. CHECK THE BATTERY TO MAKE SURE IT IS IN SECURELY IF DROPPED IT COULD HAVE JARRED LOOSE.
