Question about Insignia IS-LCDTV32 32 in. Television
When I turn on the power, this TV only stays on for about 10 seconds, then automatially turns itself off.
    President:
  • 563 Answers
There is a part inside the TV that needs to be replaced. If the TV is under warranty—whether the original warranty from the manufacture or an extended warranty purchased with the TV—call the company providing the warranty coverage and they will arrange to have your TV repaired at little, or no cost to you.
If the TV is out of warranty, and you have the experience and you know what you're doing, you can fix the TV yourself. Purchase the service manual from the manufacture to get started. However, if you've never done anything like this type of repair before and you don't know where to start, I suggest speaking with an experienced TV repair-person.
If you decide to pay for out of warranty repair by a professional repair shop, the total cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
Since some brands will pay for your repair even if you're out of warranty, you should contact the manufacture first for your full range of options. If they're willing to fix the TV for free, let them!
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today!
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jan 10, 2010
6ya staff
SOURCE:
TV won't stay on for more tha 10/15 seconds - if that
it is most likely a protection mechanism which turns the tv of incase there is a electrical problem inside. I would really suggest that you contact a local repair man and have the set checked.
Jul 17, 2008 | Televison & Video
I have a sharp LCD tv 2years old it I will press the power button to turn it on and it will stay on for approx. 10 seconds and then turn itself off. I have even tried holding the down the pwer button for a...
hope it will help you, you may have problem with power supply and inverter area. low rated and leak capacitors can cause low output voltage on the power supply the tendency is the power to reset or turn off itself. just also considered bad component at inverter area, faulty connector and back light good luck.
May 03, 2011 | Televison & Video
My TV won't stay on until it's warm?
have your unit power supply check, maybe some cold solder or leaky capacitor is the culprit.
Aug 01, 2009 | Philips 42PFP5332D 42 in. Plasma...
Will not power on and stay on
Problem is with the IC.Picture tube is OK.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
36 magnavox tv shuts off by itself
MAGNAVOX TV ONLY. 5-10 SECONDS AFTER TURN ON AUTO TURNS OFF-NO LIGHT STAYS ON-I AM FRUSTRATED BUT IT SEEMS LIKE THE OFF ON SWITCH JUST CLICKS BACK TO OFF-ALSO DOES SAME THING BY REMOTE
Jan 16, 2008 | Philips Magnavox MS3652S 36" TV
Apex pf2025 20 inch tv
timer set in menu options. Mine did the very same thing until I cleared the timer
Oct 13, 2007 | Apex Digital PF2025 20" TV
Insignia IS-LCDTV32 32 in. Television Logo
360 people viewed this question
Top Insignia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
