I use to use the DVD CD-ROM drive mentioned in the subject above to play all kind of CD's and it worked well. Until, i had problems with my registry and i downloaded the trial version of RegistrySmart to Clean it up. A month time, i used tune up utilities to clean it up as well. After this processes, the driver can no longer any CD/DVD inserted into it. PLEASE, help me rectify this code 39 error
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Follow this article to fix the issue:
http://support.microsoft.com/kb/314060
Hi! I have a ad-5540a, work all meus write DVD (power calibration), its see CD,DVD, and write CD but DVD no. Helpme please.
Are cdrw drive is missing need to know how to get it back
How do i fix code 39 problems for dvd rw ad
Try to run system restore. choose the date that the dvd rom was in good condition.
Sakjnbasmnbjnskjdnodskds
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Click on
Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
hope this helps
no se puede iniciar por error c10
plus de lecteur
PROBLEMA
tengo el poblema que sale codigo 39 y no se que hacer no me lee nada
Followed 7 steps worked perfect did not have to reinstall my DVD or "nuthin" Thank you so very much
