I solved the problem, by tipping the dishwasher back about 45degrees, I think this re-adjusted the flood sensor, and it is now working fine. Thank you.
Have been struggling with the same problem. Tipping the machine backwards worked. Many thanks.
Just noticed my dishwasher hadn't started and the check water light was on - googled the problem - got this page - did the tilt thing - all over, working again and back to normal in less than twenty minutes! This site and those who contribute are fabulous, thank you so so much.
I had fault E15 - check water showing on my 6 month old dishwasher. My fault I was experimenting using my free solar heated hot water - I tipped a couple of bowlfuls of hot water into the machine just after the cycle started. It must have activated the flood control switch judging by entries on other forums. Followed this advice by switching everything off, pulling machine out and leaving it wedged tipped backwards at about 45 degrees for 5 mins whilst I cleaned all the gunk that had been revealed behind the machine. Then lowered machine back to floor and switched on - hey presto! Now working fine and have concluded probably not worth the false economy of using solar hot water tipped in via the front door anyway! Thanks for the post.
