I have a Maytag neptune washer and suddenly it wont fill with water... hot or cold. could this be a dirty screen or bad fill valve? would both hot and cold fail?
If your washing machine will not fill, only hot or cold will fill or is slow to
fill then read these tips. I have covered many of the things that can happen in
these tips…
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
check to see if you have power to the fill valve when the cold water should be going in;(reverse the connectors on the fill valve) i.e. hot now will not go in... replace the fill valve: (buy it at an appliance parts store) (inexpensive) it's an easy replacement job
If your machine is a FAV6800AWW or FAV9800AWW the (upside down u and f) may be a “NF” for no fill error.The washer has tried to fill the machine with water and has sensed a water fill issue.The control board has shut the wash cycle down with an “NF” error to the display because of excess time to complete the water fill portion of the wash cycle. Will the machine complete the cycle with Hot water only or Cold water only?I would do a Quick Wash cycle just to test with an empty wash basket. Regardless of the above test and assuming you have good water pressure for both Hot and Cold supplies to the washer I would do the following. Close the water source valves to the washer and remove the Hot and Cold hose connections at the back of the machine and check for clogged inlet screens.If the water inlet screens are free of restrictions I would go into Service Mode and turn on the Hot and Cold water valves on one at a time and make sure the tub will fill with about 2 inches of water in about 3 minutes in service mode.Check both Hot and Cold inlet valves individually see page 16 of the SM Board Output Test, enter service mode and do the function test for both Hot and Cold Water Valve’s.If the inlet screens are clean and you have water fill restrictions in service mode we may need to look at replacing the water inlet valve assembly.You can turn on the drain pump in service mode to empty the tub or just start a wash cycle and the machine will empty the tub. The Service Manual for reference. Sears Parts Direct for reference.
Change the water valve again ,you most likely got a bad one.The odds of there being no cold water after a new valve is almost impossible.You can test the valve to make sure its working before you go to buy another one.
