I operate a home office with a Laptop, Printer and MCF-240C interconnected. I have faxability (1 line, 2 numbers) and broadband internet access. Prior to moving the office around I automatically received faxes with this configuration - no problem. Now, incoming faxes are identified (diff ring tone), 3 rings latter ring tone stops, MCF-240C picks up the connection displaying 'Receiving'. After several seconds I hear a click, display resumes to Date/Time etc, fax does not print... nor is it stored. I have tried every concievable setting without fail. I somewhat recall the setting 'used to operate' under MNL, but I cannot seem to programme it correctly. Can you step me through the process please, desperate!
My Brother MFC-8840D doesn't receive or send faxes. When I fax I hear it dialing out and then hear it beeping but it doesn't send the fax. I know the phone line works just fine and it use to work. One day it just stopped. Can some assist me with a solution.
We've shifted offices, gone from three lines down to two. I've lost the manual. One has faxability on it. It is also a step down line. At present it has the broadband on the same line.We've shifted offices, gone from three lines down to two. I've lost the manual. One has faxability on it. It is also a step down line. At present it has the broadband on the same line.
You can't post conmments that contain an email address.
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Setting the Ring Delay
The Ring Delay sets the number of times the
MFC rings before it answers in Fax Only or
Fax/Tel mode. If you have extension
phones on the same line as the MFC or
subscribe to the telephone company’s
Distinctive Ring service, keep the Ring Delay
setting of 4.
(See Operation from extension telephones on
page A-4 and Easy Receive on page 4-3.)
1 If it is not illuminated in green, press
(Fax).
2 Press Menu/Set, 2, 1, 1.
3 Press ▲ or ▼ to select how many times
the line rings before the MFC answers
(00 - 04).
Press Menu/Set.
(If you select 00, the line won’t ring at
all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Current Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing.
thanks
I found you manual to download
rightHERE: - as I´m informed, you don’t
need to change you FAX number, as your fax machine will receive any call on the
number you connect the machine to.
To select or change your Receive Mode
1 If it is not illuminated in green, press (Fax).
2 Press Menu/Set, 0, 1.
3 Press ▲ or ▼ to select Fax Only,
Fax/Tel, External TAD or
Manual.
Press Menu/Set.
4 Press Stop/Exit.
The Ring Delay sets the number of times the MFC rings before it
answers in Fax Only or Fax/Tel mode. If you have extension
phones on the same line as the MFC or subscribe to the telephone
company’s Distinctive Ring service, keep the Ring Delay setting of 4.
(See Operation from extension telephones on page A-7 and Easy
Receive on page 4-4.)
times the line rings before the MFC
answers (00, 01, 02, 03 or 04).
Press Menu/Set.
(If you select 00, the line won’t ring at all.)
4 Press Stop/Exit.
Initial Setup
1.Receive Mode
Fax : Fax Only
F/T : Fax/Tel
TAD : External TAD
Mnl : Manual
Setup Receive
1.Ring Delay
There are 2 ports on the rear, 1 for the incomming phone line, and one to plug in a telephone handset (passthrough)
if the telephone line is plugged into the wrong port, the fax machine is unable to dial properly,
So try plugging into the other port on the back, it's just next to the other port
hope this helps
