Dynex 20" TV/DVD Combo Logo
Posted on Jan 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dynax tv and dvd player troubleshooting
Dynax tv and dvd player. I've used the tv and dvd player for 2 yrs, no problem. Now I can't use the dvd player. When I put in a dvd, it says it doesn't read/see a dvd. I've checked using other 3 different dvds (and I've made sure the labels were facing the correct way).
Thanks
Penny
Anonymous
Level 2:
New Friend:
  • Expert 100 Answers
  • Posted on Jan 10, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
100
Questions
0
Helped
28516
Points
223
It may just a dirty laser pickup. You can try using using a laser cleaner cd which can be purchased from most electronic retailer.
Troubleshooting guide
Check the audio cables from DVD player to TV, usually it has 2, a red one and a white one for left and right audio.
1helpful
Sylvania (SRD3900) DVD Player / VCR Combo i can't seem to plug in the red/white/yellow cables into the right places directly to my old toshiba tv to play either tapes or dvds. can you instruct me? thanks.
Greetings - It's very simple so I'll show you how and then I think it may be another problem (nothing broken).
You need to plug the corresponding color cables into to outputs on your player I've circled above and then into the corresponding inputs on the TV. You've probably done this correctly.
PLUS - You have to, using the remote for the player, set the source to either DVD or VCR and then you have to, finally, on your TV set the input (with the remote) to what is called probably VIDEO or VIDEO1. If there is still nothing on the screen keep (with the DVD or Tape playing) hitting the TV remote input button until you see an image or you've come around to where you started.
Unless something is broken (unlikely) you should be able to watch DVD's or Tapes depending on what input you select on the player.
If it's not working you've somehow missed a step or the Video input on the TV is called something else. If that happens come back here and give the player AND TV brand/model info and someone will be able resolve your problem.
Good Luck and thanks for using Fix Ya.
Mikeywaf
Power cord jack not connecting, cannot recharge battery or power dvd player. power cord itself works well on other toys.
I have an SV2000,DVD / VCR I bought Sony Dvd`s to record from Tv to DVD and when I press record this comes up.E 4 54040990.I have tried cleaning,that does not work.I have had this DVD/ VCR about 3 2 to 3 yrs.Why won`t it record. I am so weary with it,
No color when playing dvd
try to connect cables again. make sure you push them strongly to maka sure it works. if that won't work your dvd or tv is damaged
2answers
Connecting to cable tv
if you have a cable that has 1 red 1 yellow and 1 white plug it will usually work plug the white cable into the white input and try alternating the yellow and red in the yellow input
I purchased a new Zenith Tv and have hooked up my dvd player which is about four years old (Toshiba). The connections are all right but when I put in any disk (I have tried many) it registers no disk so...
try to use player on old tv again does it still work 4 yrs old dvd player is to old for new days dvs on new tv u def wann upgrade to 108p upscaling player samsung makes with hdmi cable to new tv flat screen or reg coneection will look 10 times better also older toshibia cant play read new dvds its terrible
Graham Keenan
I presume that your TV uses Scart to connect to other devices and on your TV remote there will be a button that has either of these things next to it: 1.A box with an arrow pointing into it. 2.A button that says input. 3.A button that says AV. Turn on your DVD recorder and then push the button that i explained until you find the DVD recorder is coming up on your screen
DVD player producing poor colour image
Go purchase a DVD player cleaner. It will look somewhat like a DVD/CD and will clean the read heads. Often the issues is dirt/dust.
Semper Fi,
Z
3answers
Powers on but does nothing else
This just happened to me. Did you every figure out a solution or at least a way to get the dvd out?
Top Dynex Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
