I was told by your representitive I should up grade the unit to at least 2.36. How do i do that?
Register your unit on the magellan website,then it will be marked underneath on the site blue hit it and make sure your unit is pluged in the power cord end and the usb to the computer and unit.then and hit continue or next to go thru the process and when it is completely done and when it tells you to to unplug it do it leave the unit on and alone it will reset a few times then go to normal screen,then you are done.i did the same to mine mastreo 4000.as soon it came the firmware update.
