Kenmore h2 model 110 4646 2501 error code "add a garment" lit plus all the cicle lights FLASHING.
It drains the water but will not spin (high) to drain the clothes.
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
There was a coin in the motor filter, AND one of the sockets of the motor wires was loose.
I had to run the diagnostic test and everything seemed to be ok but the motor, did not spin. I tightened te motor sockets and run the test again with every step ok.
