We have a Frigidaire side by side refrigerator-freezer Model #FRS26ZNH and I don't know what number I should set the climate control. It goes from 1 to 6 and I don't know which number is the coldest. What do you recommend?
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Your Defrost drain Plug is clogged or kinked. Check the tube from the freezer to the fridge, make sure it's connected, then pull out your drawers in the bottom of the fridge and clear your drain hole..
unkink drain hose...I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Hi, Here is the Part # 5304421256. This is a common issue with this model. Just remove the 4 screws holding the control panel up and you will be able to see the thermostat/cold control I hope this helps you. Please let me know if I can assist you further.
This is possibly a defective control board behind the dispenser controls. The part number for the control board is 5304421827 Let me know if this helps and please rate me, Sea Breeze
The defrost systems is:
218169802 HEATER-DEFROST 5303917954 THERMOSTAT-DEFROST 5303917954 TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
