Dish DVR625, 2 TV system. Channel on TV2 was inadvertently changed from 073 and DISH remote will not allow channel reset. Green reset button on remote did not work. Cannot access channel manually on the TV (it skips 73, original remote for TV does not work). Tested DISH remote
with TV1 on System Info screen - remote does react. Changing 2 digit remote address in System Info does nothing.
Thank you.
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
I have dish network and cannot get anything to
work with my remote.
