Hello, I have a Whirlpool DWF A10. The machine starts then stops after a short while and the indecator light flashes 7 times. What does this mean? Any body come across this?
Some times the Tech sheet for the machine is located on the back side of the kick plate.
This sheet sometimes will give you the blinking error codes. as log as someone has not removed it.
This is the first place a tech will look for help with your machine.
If its the clean light that is flashing check the heater for an open circuit. If its not in the heater then probably the control board. According to whirlpool it could be a thermistor but Ive been working on wpl dishwashers for years and never seen a bad thermistor. If its not the clean light only flashing than disreguard all info that I have just given you because its probably another isssue. Hope this helps
