We have a Breadman Healthy Options (Model No 12683), it served us good in the past few years, but today decided to die on us.
Symptom: it beeps for 5 times when it gets plugged in and then shows ''_oo'' on the display. Whatever command one tries, it (annoyingly!) beeps and gets back to showing ''_oo''.
Without being a specialist, it seems like a circuit just died -any suggestion will be highly appreciated.
Many thanks in advance,
Adrian
Https://www.modelrailwaysdirect.co.uk/Ratio-528-Water-Tower-GW-Pillar-%28conical-or-flat-top%29
Ratio OO Building Kits Antics Online Model Shop
I have not found build instructions online at this point, just these kits.
SOURCE: ERROR PROBLEM?
Hello this is Spur21,
It sound your machine as an defect and should be returned to the place you purchase it, unless you are willing to contact the Manufacture for assistance. Refer to your owners manual for telephone number. Good luck,
Spur21
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
SOURCE: Sansa express shows "sandisk" in the display for 5 seconds and then dies.
Reset should work
These are the most common methods for recovering Sandisk's Sansa Mp3
Players. I have been almost universally successful in recovering Sansa
players using one or a combination of these methods. These methods do
not work if you are having synchronization or music format issues -
they are for recovering a player that will not power up, freezes,
flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the
computer and open Windows Media Player. Click on the Sync tab. Pull
down the drop down menu underneath the Sync tab by moving your cursor
over the Sync tab and left clicking on the little black arrow
underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary
slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware
upgrade from Sansa - it updates the firmware and erases every song in
the player all at once. Note: this method doesn't work if already have
the latest firmware. Go to this website and click "Firmware Updater" to
find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off,
hold in the volume + button, and reconnect the player to the computer
while holding the volume + button in. Keep holding the volume + button
for an additional 5-50 seconds. Windows should eventually go into
recovery mode and revive the player- it will pop up a window that says
Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods
to get them to work properly. Disconnect your Sansa player BEFORE
shutting down your computer.
-Tha Mp3 Doctor
SOURCE: I have a Breadman Ultimate
Check the power socket it may be worn. If you suspect the plug it is easy to install a new one. Just keep the polarity correct
Well it shows the lock on the screen because you have it locked. Slide the lock button on top of the player so that you cannot see the orange spot.
