Sansui VRDVD4001 DVD Player/VCR Logo
Anonymous Posted on Jan 11, 2010
I can not get it to record at set times. - Sansui VRDVD4001 DVD Player/VCR
  • Anonymous Jan 11, 2010
    The clock is set.
    I do NOT have the manual.
    I have NEVER gotten it to record at a set time.
    It has been unplugged and plugged back in.
    I can not get my Sansui VRDVD4001A to record at a set time.
A
Anonymous
I have looked everywhere on the web for a free owners manual and could not locate it but I did find this one for $2.78, click on the link below, this manual will provide you with the exact information you need to record set times on your Sansui VRDVD4001 combo player.
http://www.orionsalesinc.com/miva/merchant.mvc?Screen=CTGY&Store_Code=OSI&Category_Code=VRDVD4001
http://www.sansui-india.com/
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Jan 11, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5033453
Points
35540
Is the clock set?
Do you have the manual?
Have you set it in the past and have it work properly?
Unplug it for an hour and re-try.
Thanks
Video only records 40 seconds why?
This is most likely a timed recording settings problem. Check all timer settings, one of the recording settings must be set at 40 seconds running time. If you don't require this recording function then change this setting to the appropriate (not applicable/zero setting), or conversely set this setting to maximum time possible.
How to record
Be sure you have first set the clock correctly. After setting timer recorder time, channel, speed etc. hit enter to highlight the setting to be sure you have it. Press setup to put you back to tv screen. Then press t-Set button on remote. Unit will automatically shut off and there will be an amber symbol on the unit lcd along with the time. This indicated the unit is in the timer mode. It will automatically turn on and record the program at the set time.
I have a vwm-400 Sanyo video cassette recorder. The clock on the recorder is set to the correct time! I programmed time recording for a set time to record a program on TV, but timed recording is not...
After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel.
Let me know if you have additional question.
Thanks.
Timer
You can schedule for automatic recording, specifying the start time
and end time of recording. When the timer-controlled recording
completes, the setting is released.
In Menu mode selection... SET, On, OFFAfter selecting SET, press the PLAY button to set the time to start the recording.
Set the timer to record
Do you have the remote which came with it? Most VCRs of the last 10 years require the remote to setup a timed record, or for that matter, most of the advanced functions- beyond play/rewind/ffwd, etc.
Assuming you do have the remote, and the correct time is set, and the timed record properly setup, some VCRs require a the On-Timed-Record button to be pushed. This sets the VCR in a wait mode, until the time set for the recording to begin.
Consult your owners manual- an online manual may be available if the printed one is missing.
Toshiba DVD recorder timer recording does not start
Does the unit not require to be in "Standby" for recording to commence.
Timer recorder n/w
the recorder must be off, otherwise timed recording doesn't work
Recording Late
Check your automatic clock setting. If it is on automatic, set it to manual, and set the date and time on the recorder. It may be picking up an unreliable time setting from a station that is not too accurate.
tom
2answers
Set a timed recording
Do you have your operation manual? It will tell you how to set up a timed recording. Recording options are set via the remote. Look for an option as "Scheduled recording" or similiar. Date, start & end time, channel, recording speed are all set. If you are missing your manual do a google search with your model number. A quick look at the Samsung website was not fruitful.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
