SOURCE: bra wire stuck somewhere in machine
You will not see it as it is trapped between the inner and outer drum, what you need to do is remove rear panel and the large hose from the pump to the bottom of the drum,
Then reach in with your fingers and see if you can feel it , if you can't then short of removing the drum (not recommended) ther is not a lot you can do, hopefully it will find it's way into the filter, where it wiil not be a problem
Plz rate this solution.
SOURCE: HELLO , I HAVE A HOOVER NEXTRA MEGA LOAD WASHING
i RATHER USE A ******** THAN A WASHING MASHINE!!
SOURCE: hoover nextra hnf2137 wont drain
Take a look at my article http://www.fixya.com/support/t3144835-not_draining_water_not_spinning Hope this helps
SOURCE: Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
SOURCE: My Hoover Nextra 6 has
It could be anything but one of the most likely things is a faulty door switch. What were the circumstances leading up to the fail ? Have you checked the filter? Is there any water in the machine?
Try unplugging it and leave it off for 15 mins.
difficult without any more clues...
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
