Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
Posted on Jan 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 3"-4" pink/purple stripe across the top of my KDF-55E2000. New lamp installed just today. any Ideas
Anonymous
Level 3:
  • Master 556 Answers
  • Posted on Jan 12, 2010
Anonymous
Master
Level 3:
Answers
556
Questions
0
Helped
154247
Points
1096
Sounds like bad light engine.
3helpful
TV Model: Sony Wega KDF-55E2000 Projection lamp warning is on..and today a light red bar appeared at the top of the screen and light blue on the bottom..is this because the projection lamp needs to be...
Hello
There are two possibilities for this fault with Sony Projection tVs. The first is with the lamp itself. The second one is with the lamp ballast baord. Replace the lamp ballast board first. Because, it there is any internal winding short in the inverter transformar of the ballast board this type of fault can occur. you have to replace the ballast baord along with the new lamp anyway. Therefore, replace the ballast board first. If this help you, there is no need ot replace the lamp. Picture of the ballast included here for you to compare.
gopakumarg43_36.jpg If replacing the ballast dis not help you, change the lamp too. OK.
How do you replace the projection lammp?
I will forward a link to a page where you can find the instructions on replacing the lamp of the TV.
http://www.docs.sony.com/release/KDF42-46-50-55E2000.pdf
8helpful
2answers
Sony kdf-55e2000 tv
This indicates problems with the image engine. (Lamp does not control the colour). If the TV has not been cleaned recently, excessive dust build up internally may have overheated the image engine. If Sony will not cover it, you might want to consider a new TV.
1helpful
SONY KDF-50E2010 HAS PINK STRIPE ACROSS TOP OF SCREEN
it might be the cabels
on dvd it is the same?
1helpful
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
2answers
Sony Grand Wega KDF-50E2000 with a red stripe on top of Picture
There are some adjustments that can be made to align the picture. This might correct your problem. They should only be made by trained serv tech. If that won't fix it then replace the light engine. There are 2 different ones for this model. They are serial number sensitive.
Pink or magenta stripe across the top of my sony kdf-55e2000
Sony has extended the warranty on the optical block which you are experiencing a problem with until June 30 2010. Read about it here. http://www.agoraquest.com/display_alert.php?alert_id=17
Purple band at top of tv screen
Please make sure you have the Lamp seated properly in the set. If you purchased just the lamp without the basket make sure it is Flush against the front of the lamp basket. The light path is being obstructed or not aimed properly. Let me know, hope this helps.
3answers
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
