Sansui COM312AD 13" TV/VCR Combo Logo
Posted on Feb 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sansui tv/vcr combo is stuck on highest volume.
HI.
I got this tv from a friend and he said that he volume was stuck. well he was right, the volume is stuck on 64 and wont go down. How do we fix this?
Simpson Neal
Level 2:
Novelist:
Champion:
  • Expert 236 Answers
  • Posted on Feb 19, 2008
Simpson Neal
Expert
Level 2:
Novelist:
Champion:
Answers
236
Questions
Helped
82439
Points
343
If you have the remote,have you tried it ?
Have you tried the volume button on the front of the set ?
If neither the remote or the button will work, then you may have a problem with the microprocessor IC (system control). If this is the case, then the set might not be economical to repair.
Perhaps the volume "up" button is stuck ?
SANSUI TV/VCR COMBO. WILL WORK ON DC CAR BATTERY. DOES NOT WORK ON HOUSE CURRENT. 110 IS REACHING THE BOARD. FUSES ARE GOOD.
Hi Matt, for what you say the internal power supply of the Combo Sansui, 110 volts a12v, is not working
Indicate model of Combo Sansui, which you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Matt, por lo que comentas no esta funcionando la fuente de alimentacion interna del Combo Sansui, de 110 volts a12v
Indica modelo del Combo Sansui, del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
What is the code for sansui home theater DVD from a universal remote Wizard 2
Ok I do not have a code specifically for what you mentioned yet in checking all the Sansui devices, there are not that many and some codes repeat; So I listed all that I have for Sansui's: TV's: 0135,0310,0394. VCR's: 0310,0376,0377,0394,0256,0967,0303. CD's: 0666,0704,0723,0734. DVD's: 0394,0967. TV/VCR combo: 0310. TV/DVD combo: 0394. DVD/VCR combo: 0394,0967.
You will note that the BOLD ones repeat for many devices, give those a try first.
1helpful
I have a tv/vcr combo sansui tv with no remote and i have universal remotes which none of the sansui codes work. Any suggestions? What company makes Sansui?
Hi! actually most sansui are manufactured from china, so you should try the codes designated on china brand of tv"s.
I have a 2004 sansui 13 in screen tv vcr combo no manual. How do you program the vcr to record?
MAIN MENU ON THE COMBO ,,UNDER SETUP ,,SET UR CLOCK ,,AND YOU SHOULD FIND IT ALL THERE
Rcr311w codes for sansui tv/vcr combos
CLICK HERE for your user manual.
There are 4 ways to enter the code.
Thanks for using FixYa - A FixYa rating is appreciated!!
Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
20helpful
4answers
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Buy a sansui 6 inch tv vcr...
As far as i know,this product is no longer available. You can try on ebay.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
