I have newVizio 1280/360 TV. Model # SV320XVT and trying to sync my Magnavox Digital video disc recorder & video cassette recorder with digital tuner model # ZV450MW8A. I cannot play any movies on my new TV because cannot find the correct component code. Tried using all listed in the magnavox user manual and the Vizio user manual. Tried everything. Does anyone know anything about playing DVD movies on the Vizio?
SOURCE: Magnavox MWR20V6 DVD
I just called Magnavox about a similar DVD/VCR combo and they said you can't use any other remote with those for some reason.
SOURCE: Magnavox ZV450MW8A can't record
I have a friend who is looking for ther Owner's Manual for this Magnavox model. (ZV450MW8A). Please contact at [email protected]
SOURCE: HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
SOURCE: I Have been trying to
--- for some reason this unit does not finalize automatcally.
--- the instructions for finallizing are on page 52 of the owners manual.
--- they are as follows:
1) Press Setup
2) Scroll down, select "Disc Edit", press "OK"
3) Scroll down, select "Finalize", press "OK"
4) Select "Yes", press "OK"
Finalizing will start.
--- have done this operation several times, works Ok.
Joe
SOURCE: I just bought a Magnavox ZV450MW8A DVD/VCR
Yes, you can, I have this unit and have actually copied a dvd to a vhs and then copied back to a dvd as I wanted a dvd copy to give a friend. The directions in the book are really quite simple. They tell you how to set the vhs to the spot where you want to start copying, etc.
I have not yet tried copying my family vhs tapes, but don't see a problem, just a big project. Good luck.
