Sony Bravia KDL-40S2010 40" TV suddenly lost the ability to project red, even after adjusting the Picture and settings (all the way up with red), warm1 and 2, etc. Other colors are fine.
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 30
Hi.
Sunday evening the picture on my Sony Bravia suddenly went very red and there are blurry lines after action. TypeHi.
It is symptom of weak Lamp (bulb) that requires replacement. You can buy Sony original lamp from Sony Accessories Store. Lamp required for KDF-42WE655 part number is as follows.. A1606034B
LAMP BLOCK XL-2100U
Are you connected to a cable box or satalite rcvr using compoment outputs (y,pr,pb)? It is posible that the red cable has come loose and picture has no red,causing a mostly blue picture.
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
