Williams 2509612 Ceramic Mid-Size Heater Logo
Posted on Jan 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello. I just moved into an apt. with a Charmglow Propane Stove..Model # CGL250TE. Do I need any ventilation precautions with this stove??
  • Anonymous Mar 15, 2014
    wont stay lit
Anonymous
Level 2:
  • Expert 221 Answers
  • Posted on Jan 13, 2010
Anonymous
Expert
Level 2:
Answers
221
Questions
0
Helped
96006
Points
896
Hi, any gas range or oven does not need to be vented to the outside. The reason is that this not a heating device and is meant to be used for short periods while preparing meals. People get into trouble when they try to heat the apartment by running the oven all night. If you happen to be cooking for an extended period, you may see extra condensation on the windows but opening the window a crack will help. Of course if you smell propane when your not using the stove, that would indicate a leak and should be taken care of.
  • Groovy Techhound
    Groovy Techhound Nov 21, 2017
    You shouldn't pretend to know the answer to this question when you obviously don't. The reason all Vent Free stoves, fireplaces, etc can be used as heating appliances, is because they.... unlike Gas Cook Stoves and Ovens they have an Oxygen Depletion Sensor. Although it's using a Passive rather than Active Sensor.... it's actually extremely dependable at making sure you don't wake up without oxygen to breathe or worse DEAD.... from a lack of oxygen.
    But.... if you take steps to make sure you have a balanced air intake and exhaust system.... (especially in more modern totally sealed houses/apartments) then follow what the manufacturer suggests in the instruction manual that comes with this Gas Stove.... you will be safe with that Oxygen Depletion Sensor doing it's job.
    Safety points to remember; first off is making sure you have adequate clearance from combustibles in front of the stove at all times. Plus you can use near any window exhaust fan to both exhaust air out and bring fresh air in from another window. This will prevent moisture build up in a sealed building or room. It also keeps soot build up off curtains and walls then too. Especially if you use a good air cleaner like a Negative iON Generator or Ozone creation filtering system. Ion Generators help keep the air dry and are actually very close to the effects you get after a Lightning Storm that cleans the air outside.
    If the building you want to heat is fairly drafty or leaky as it is, then you probably won't need to supplement Air Exchange between inside and outside air. Then if you go through proper break in period, you won't have the smell that comes with the typical log set burn in problems.
    You can use this as a room or whole apartment or house heater up to about 800 sq ft. Just be careful of what you set close to it, like you would an open fireplace. Because it's just like a fireplace with a Fire Screen. It's the open flames that are what can be dangerous. NOT ever the fact that anything that burns up lots of oxygen while in operation are oxygen depleting!!!
1helpful
2answers
Can you use propane for this stove ?
no info on stove so cant answer correctly --but most can be converted or have a conversion kit available do online search of make and model
What kit do I need to convert to propane, or is it built into the stove? Got it used
Look under the top cover of the stove top. They may be in there. If not, you can get them online or at an appliance parts store. Just google propane conversion for the make and model of your stove.
I have a Charmglow propane heater model CGL300TQ with a bad fan. Where can I find parts for this stove and does Charmglow have a website for parts?
Depends what is actually wrong with fan, if tis the blower barrel part you can by replacements but if its the fan and you van't find manufacturer try an commercial or indutrial fan place to match the one you have be careful to make sure that it is electrically compatible and that it will connect to heater safely and do as old fan did as fan speeds on heaters can be important
My (new to me) apt has an electric jennair stove top -no instruct
Try http://www.jennair.com/flash.cmd?/#/page/home
Click on cooktops.
I have looked, but cannot find your model number. Perhaps if you look, you may be more sucessful, they do have pics and descriptions.
Propane was turned off for unrelated problem propane turned back on stove will not lite
If your stove has a standing pilot, it will need to be re-lit.
If this does not help, state the model of your stove.
2answers
Black is on the burners
the fuel to air mixture is set incorrectlty or your pressure at the ouitlet for the gas valve is too low.
you culd play around adjusting the first part of this but for the gas valve part you have to have a manaometer to check it out correctly. then it should be set at 10"wc. Good Luck
I have a used kenmore propane gas stove that i just bought from someone. We have hooked it up but can only get the oven to come on. The stove top burners will not come on. We we turn on the burners we do...
In the old days stoves were lit with a match. If this does not work for you it would be due to the stove's lines remaining "airlogged" after the move. The oven purged and ignited more easily because it has a much larger orifice, so the air bled more quickly. I expect if you were to leave one burner turned on long enough for the air to bleed out you will find it to ignite normally. Do not leave the stove to bleed unattended, and if you encounter a strong smell of the gas, turn off the burner, and ventilate the room as needed. The smell of gas would indicate that gas is present, it may be possible that a lead came disconnected from the ignition module in the back of the stove. Again if this is the case, the ol' match will light the burner. Be Careful!
Top Williams Heating & Cooling Experts
Paul Carew
NOEL
NOEL
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
