Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
I'm not saying you don't have a problem. But just to be clear. You do understand that the last minutes on these machines can vary. The machine senses certain conditions in clothing, water discharge, etc. So sometimes the "1 min left" indication can stretch into many minutes. In theory, at least, it's possible your machine just needs to be left alone until it finishes whatever it's doing. However, one would think that any issues not resolved in 10 - 20 min are an indication of a problem. So i guess that's my next question, did you wait long enough? Keep in mind i am not a kenmore expert.
if there is water left in the machine it will not open pull out the washer if under work top tilt the machine back wards the door should open thwn clean filter and try
if this a manuel timer,,you either stripped the ,,knob,,or you broke the timer its self...make sure that timer can be pushed and pulled,, pull ----on push is off
you have a pump problem, need to lean washer back ageist wall go under washer. front left take off both hoses stick finger in pump remove all items from pump &hoses should work now
