That is actualy a DE (drain error) code. Open the access door at the lower left on front of the washer. Use the little hose to drain the remaining water out of the machine. Now, unscrew the big knob next to it and remove the attached filter. Clean out the filter and re-install. If the filter was clear, you will need a new pump motor.
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
