Question about Panasonic Lumix DMC-LZ2 Digital Camera
My panasonic lumix dmc-fs3 will not connect to my pc so I can upload pictures. It is not my usb port because I can plug other things into it and works fine. This happens with any usb cord I try to use. Also when I try to connect it I get a message that says picture is displayed for 4:3 tv for a 16:9 setup and even though i've reset all the settings on my camera it still comes up
    Brigadier General:
  • 11,967 Answers
Start using a card reader instead of your camera.
Posted on Jan 13, 2010
6ya staff
SOURCE:
SOURCE: our lumix dmc-fs3 camera says the memory card is
It should have a little switch on the side. You slide it down to lock, up to unlock.
Posted on Feb 12, 2010
Thomas F. Schneider
  • 2715 Answers
SOURCE: lost manual
It is in this list of downloads:
http://service.us.panasonic.com/operman/findmanual.aspx?cat=CAM
Posted on Jan 10, 2009
Ty Price
  • 11967 Answers
SOURCE: I cant upload movies form my Panasonic Lumix® to mac
You could try using a card reader to upload the videos to a folder on your desktop.
Posted on Apr 29, 2010
Ty Price
  • 11967 Answers
SOURCE: My panasonic dmc-fs3 lumix is
In the setup menu, find "reset" and follow the on-screen instructions.
Posted on Oct 31, 2010
  • 102366 Answers
SOURCE: My panasonic lumix dmc-fs3 digital camera won't
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Apr 30, 2011
How do I take panoramic photos on a Panasonic Lumix DMC-FS3, have done it before, but forgotten how to set it up.
Enter "setup" mode, and switch from "picture" or "video" to "panoramic". Take a picture, move the camera, and take another picture. Follow the on-screen instructions when you have finished taking the segments.
Feb 24, 2015 | Panasonic Lumix DMC-FS3 Digital Camera
Panasonic DMC-155 camera no longer uploads photos to PC
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Jun 02, 2013 | Panasonic Lumix DMC-FS5 Digital Camera
How to copy my photo from internal memory to memory card without usb or dc input?im using panasonic lumix dmc fs3
Go into the camera menu and find "copy". It gives you the option to copy the internal memory to a card.
Dec 23, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
MY LUMIX WONT UPLOAD PICTURES it did it last week
Dec 03, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
My panasonic lumix dmc-fs3 digital camera won't upload my pictures. It worked a month ago and now when i connect the usb to the computer the camera screen says "connecting to pc" and nothing pops up on the...
Sep 03, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
Problem with uploading pictures- they go weird.
This sometimes happens with cheap cards. Also, set your camera to take the highest quality pictures.
Jan 24, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
I cannot upload picture onto my pc
Does the PC pop up with anything when the camera is plugged in? if so, make sure the camera is in plyback mode and check windows explorer, under My computer, there should be a extra drive letter pop up.
If not then the USB socket can become damaged easily (have a look). If the socket is damaged, then you can either get it repaired or buy a SD card reader. that stays connected to the PC through it's own USB cable, you take the SD card out of the camera and plug it in to the reader (this is a better and cheaper option)
Cheers.
Sep 29, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Not uploading pictures
I think I know what the problem is, first off the computer must be able to communicate with the
camera/device irregardless of the drivers. The camera is plug and play and so is the computer
unless you are using an older version of windows like 98 or 98 second edition. If you are 98 etc load
the old drivers. But if you are 2000, millineum, or xp then the drivers are automatic for the usb ports.
The panasonic dmc-fz7 is kind of a freak in that it is not a true plug and play device. Sometimes
you have to declare the new hardware. It may have once worked but for what ever reason the hardware may not jive with what the pc thinks it sees if anything at all.
Solution: Go into the Control panel , add hardware wizard, with the camera hooked up to the usb
port and the camera turned on. In the device manager you should get the appropriate message, "new hardware detected" actually it should say dmc-fz7 etc. From there it should be apparent that things are working normally....Good luck. Probably a power glitch or who knows. Mostly its a problem with panasonic plug and play software which they corrected a year or so later with the newer cameras...
Dec 22, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
337 people viewed this question
Top Panasonic Cameras Experts
Ekse
Tom Chichester
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
