see this causes and fix it. God bless you
If the microwave doesn't heat the thermal fuse may have blown. It can be
tested for continuity. Watch our fuse testing video for more
information.
If the microwave does not heat, the high voltage transformer might be
burned out. Microwave ovens produce a very high voltage in order to
power the magnetron antenna, which emits the energy that cooks the food.
If the microwave doesn't heat the high voltage capacitor might be
defective. The high voltage capacitor works with the high voltage diode
to convert the output of the transformer to DC voltage and to double the
output voltage. If the capacitor is burned out the entire high voltage
circuit stops working properly. The high voltage capacitor can be
checked with a special VOM meter which has a capacitance testing
capability. Be aware that the high voltage capacitor can retain a charge
of more than 3,000 volts and can injure or kill a person if not handled
properly. Only trained technicians should perform this type of testing.
If the microwave oven doesn't heat the magnetron tube might have burned
out. The magnetron uses high voltage, high current DC power to generate
the microwave frequency that cooks the food. If the microwave oven is
turned on when it is empty this can cause the magnetron to burn out.
Once it is burned out it has to be replaced, it's not repairable.
If the microwave does not heat, one of the door switches might be
defective. Microwave ovens normally have three door switches, if any of
them fail the microwave does not turn on and does not heat. Check the
switches for continuity with an Ohm meter.
The high voltage diode converts the A/C power output of the transformer
to D/C, doubling the voltage to nearly 5,000 volts. This high voltage
powers the magnetron which emits the energy that cooks the food. If the
diode burns out, a lower A/C voltage reaches the magnetron, which is not
sufficient to power the magnetron. When the diode fails it is often
visibly burned out. If it appears to be good, it can be tested with a
volt-Ohm meter capable of testing diodes. High voltage diodes frequently
fail and are one of the most common points of failure in a microwave
oven.
