Hi I'm trying to hold of a spare part for an NEC NFL855. The part number is SN 02340040 or PO 101007529. Any idea where I could get the part from? [email protected] Trevor Norton
How Do You Get Service?
If repairs become necessary or spare parts are needed, please contact via telephone at (1-800-763-6699) or via email [email protected], or please write to:
BRIEL Service Center
250 Halsey Street
Newark, NJ. 07102Website: Service Center
What if you have questions about your machine?
You can contact our BRIEL offices via telephone at (770-509-3006) or via email [email protected], or write to:
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers,
for spare parts and service, Driver
downloadsand
Installation Instructionsas required.
This is the best way of ensuring up to
date drivers for your system and they are free of charge!
E3 error is discharging water problem. ie 1.the pump not working (under bra wire will stop it spinning) or 2. the discharge hose blocked or most likely 3. the pump inlet hose from the drum is blocked (with small article of cloth or coins or similar). To Fix: 1. Open the pump filter and check if spinning during empty/spin cycle, make sure nothing jamming or twisted around impellor. 2. Check discharge hose is not crushed or kinked. 3. Lay machine on its side, access pump and remove inlet hose assembly and remove any blockage. Jeremy
Tod, I've just hung mine on the wall, and have spare (black) feet. Let me think about it for a while, I may need the feet myself later - If I decide I won't I'll let you know.
Have you managed to get 720p into the panel? I tried to get my Sky+ HDMI into the panel and I get no picture at all. Have you tried that?
