Question about Ricoh Aficio 2022 All-In-One Laser Printer
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset the error  code but I don't know which buttons to press. Please help. Peter
  • RONALDO PANLAQUI
    RONALDO PANLAQUI Feb 10, 2014
    try to reset if u the program
  • Bebboo Bebo
    Bebboo Bebo Jan 10, 2019
    this option Sp 5810 not found.What replacement?
  • 163 Answers
Sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
    New Friend:
Toner on the terdmisters and thermostats if the buildup is severe the hot roller may be out of place meaning you may need new lower casing.
Posted on Mar 02, 2010
    New Friend:
Paper misfeed message
but their is no paper missed
how can I reset this message
my email: s_hroub@hotmail.com
Posted on Jun 29, 2011
6ya staff
SOURCE:
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Aficio 270, Sc 392, error code
Good morning,
I need help, my Ricoh Aficio 1022 with this error SC-392 is an error of sensor density toner.
I've only had the unit for another and still the same, and the unit is running on another machine.
Already cleaned the connectors Unit
Please if someone can help me.
E-mail: cybercopy.udi @ hotmail.com
Jul 16, 2012 | Ricoh Aficio 1515MF All-In-One Laser...
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
Code shows SC 548 how do I clear this
SC548: Fusing unit installation error - Definition - [A]
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -· Fusing unit is not installed
· Poor fusing unit connection
check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion,
this sc 548 usually happens when paper jam occurs and user does not properly fit the fuser... also not fiitted properly due to some foreign object in between fusing belt and the sensor...
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps. if this doesnt solve ur problem then try contacting ur ricoh service tech
good luck
Aug 09, 2009 | Ricoh Aficio CL3500N Laser Printer
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Error code sc 306 aficio 1022
I don't show a "306"....please re-check the code.
Have you tried turning off the main power (red button on front), and/or unplugging the machine to try to reset it?
Mar 18, 2009 | Ricoh Aficio 450e Laser Printer
Ricoh aficio 1022 sc 546
problema ricoh aficio 1022 copia en blanco aparece codigo
sc 193
Oct 20, 2008 | Ricoh Aficio 1022 All-In-One Laser Printer
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
Ricoh Aficio 2022 All-In-One Laser Printer Logo
5,639 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
