Question about Samsung S860 Digital Camera
Usb port not working
I plugged up my usb port and it only says it is connecting to the computer. Then my computer says that it does not recognize the USB, It has not done this before.
    Brigadier General:
  • 11,967 Answers
Do what the pros do...use a card reader.
Posted on Jan 15, 2010
6ya staff
SOURCE:
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
I tried the troubleshooting below, and now my mouse and keyboard are not recognized by the computer so I cannot do anything on the computer! HELP!!!!!
If the connections are usb connections then restart the pc with the 2 devices plugged in properly. If that is done n no progress it could be d port on d system BUT try all usb port first! Will be waiting for a reply.
KJR
Jan 10, 2013 | Dell Dimension 3100 PC Desktop
Every time i plug in my sony camera to the usb port to upload my pictures, my camera will say " usb mode. connecting to mass storage" then that will go away after a few seconds and then it...
The "USB mode" and "Connecting to Mass Storage" message will get displayed when the Camera is connected to the Computer and is recognized by the Computer as a Mass Storage device. This is not an error message and is a normal operation.
You can change the Mass Storage settings in the Camera (depends on the model) The USB Select or USB Connect option in the Camera can be changed to PTP, Mass Storage or PictBridge mode. Set the option in the Camera to PTP and connect it to the Computer and check if the Computer is recognizing the connection. Once the computer is recognized, it appear as a removable Drive.
You can transfer the images from the Camera to the Computer from the Removable Drive by copying and pasting.
Thanks for contacting FixYa.
Apr 07, 2011 | Sony Cameras
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
Dec 15, 2009 | Computers & Internet
USB ports wont recognize anything I plug in
Are you using XP? If so:
Here is what you can do to refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB device.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 02, 2009 | Acer Aspire 5100 Notebook
Computer no longer recognizes my scanner
If you are using a multi port USB adapter that allows you to plug many devices into one USB port it may interfere with the scanner. Try uninstalling your Epson driver then download the newest one from the Epson website. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=All&x=27&y=14
Install the newest driver first then plug your scanner into a single USB port on the computer instead of the multi port.
Mar 31, 2009 | Epson Perfection V500 Flatbed Scanner
USB port problems with hp printer
use 2.0 ports and not less than that.if still nothing works out,check your port connections or that of ur printer.
Jan 03, 2009 | HP DeskJet 3745 Printer
USB DEvice not recognized
I had a problem like this -- tried plugging the camera in to the rear USB slots not the front ones and it worked fine.
I think that it doesn't like going via a USB hub, but wants a direct connection. All of the USB ports on my computer are connected direct to the motherboard (i.e. none are on PCI cards or anything), but looking at the hardware info for the computer, it looks like the motherboard has a few "direct" USB connections, and then an on-board hub which the front ports connect to. If your computers are the same, that would explain things. I'd suggest trying each USB port one at a time (turn the camera off before plugging in, and back on when in) and see if one of them works. Wouldn't hurt to power the camera from the mains at the time too.
Jan 01, 2009 | Video Cameras
Compaq Presario v2000 w/ dead USB ports
Does 1 Usb port work on your computer? Sometimes they can go out. Do you have a USB hub you can use?
Jul 19, 2008 | Compaq Presario 700 470024-192 Notebook
Samsung S860 Digital Camera Logo
61 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
