Hi i can not locate the element to test it. where do i find it and what does it look like
My six year old Electolux Dishlex DX 403 dishwasher stopped heating the water. I found comments on the internet about burnt out solder joints in the control box. A friend opened the control box and found a blackened area on the back of the circuit board. Once the connection was re-soldered the water heated again. We also found that quite a few wires leading to the control box had overheated and the insulation had melted. Considering that this dishwasher was the top model from Electrolux at the time, I was not impressed. I had previously had a Vulcan Dishlex for almost 20 years.
Thanks to those people who previously posted information about this fault.
Hi
mine had this exact same problem - it turns out that the relay on the control board had not been soldered on properly. mine has shorted out over time, and caused a lot of charing of the localised area. i checked the relay, it was okay, so have resoldered the board and all is working for now.
i called Electrolux - 1800 001 218 - to report the problem, as i believe there are too many peoplew reporting this issue for it to be a one off. i was also concerned about a fire risk, as the charing on mine was considerable.
too be blunt, Electrolux didn't seem to care too much, unless if i wanted to pay to have someone come look at it, despite the fact that i am an electrician.
Electrolux currently say that this is the first time this problem has been reported - despite that fact they are aware of this thread. i would encourage anyone whoi has this fault to call the above number and report your problems to them, as i believe a recall may be waranted, and, should your unit have serious problems (fire) it is on record.
Electrolux currently have a recall on a couple of other dishwashers due to the fact they pose potential fire risks - see www.recalls.gov.au
The heating element is hidden is this model of dishlex.
SOURCE: i have a dx302. its not heating the water or drying.
Based on your question, location of the heating element:
However, a couple of things you can try:
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
I have an electrolux dishlex dishwasher DX 403 WB and cannot find the heating element to test it. the water is not heating.
I also have a DX 403 and sometimes it gets hot, other times it doesn't
We have the same dishwasher 4yrs old with same problem.On phoning a service agent and asking to bring a new element his visit advises that the fault is in the circuit switch control unit and the cost of the repair and new
circuit control replacement is $294 with a new waste water hose which is also needed.About one third of a new washer. Alex
No assistence needed as will buy another washer
