Try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Is it a front loader, top loader, what make ? Too many different types and makes to determine the fault. Have you checked to see if the cycle is on drip dry? If it is, the machine wont spin and leaves all the water in the clothes.
Check pump is not jammed or pump / drain filter is not blocked , if so clean /free and re-try , may not require any parts . refer to handbook for location of filter .
It is possible that the belt at the back of the machine is slipping. try running the spin cycle without any load in the machine. I assume this is a front loading machine and you are in UK. the Belt is available on line for about 15 pounds.
If it is running the washing cycles normally, it can't be the motor.
Machine won't spin
