Indesit WIE 147 - taking water in and draining (nothing else happens) - display shows 'F-03'. Please advise any possible fault and solution... Thanks. Tom
Indesit washing machine error code 3 (F03)
On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Replacement thermistor available from Partmaster direct for £8.75. See the link below
Easy to replace - located at base of drum in heater element assembly - to replace disconnnect machine from mains, remove rear cover - heater assembly connections are easily visible at the base of the drum - the thermistor is on the right hand side.
http://www.partmaster.co.uk/cgi-bin/prod...
Have had my machine 2 years ..has f-07 display( WIE157S)....cycle seems to stop...can anyone help???.
My machine does the same,what you need to do is hold the door shut till its in cycle.hope this helps
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect as IT SEEMS THAT THE INLET AND THE OULET IS OPEN AND SO ALL WATER DRAINS OFF AS IT COMES IN.
So please check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
have had my machine 2 years ..has f-03 display( WIE157S).keeps filling up with water......
Indesit WIE 157 S, displaying F-03 code. I have the same problem.
Dear sir
Would you please explain about ERROR F 13 IN Indesit Washing Machines and Washer Dryers WIE 107.
Thanks
