Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
Don Saylor Posted on Feb 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Epson Photo RX600 error messages
Can not get printer to feed paper. Have a "Paper out or paper feed error - Please insert paper or clear the paper feed error, then press the color button". Started when I tried to print something but printer had run out of paper, usually it will just ask that paper be put in. This time the machine made several "grating" sounds and I got the "paper out/paper feed" error. Now each time I try to get it to print I hear 3 beeps and then get the error again. Thanks
Rommel Balcita
Level 3:
  • Master 749 Answers
  • Posted on Feb 10, 2008
Rommel Balcita
Master
Level 3:
Answers
749
Questions
Helped
376870
Points
2156
Hi.
Check for a paper jam inside the paper feeder... There's something blocking the path that is why the 3-beep is activated. Also put lubricant to the head's round-bar, gears and levers.
Goodluck... Fixya me...
Epson stylus photo rx585
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
4helpful
2answers
Epson Stylus Photo R350 giving a paper jam error message
An Epson service man (he was VERY kind to suggest this) told me to use a weak detergent solution on the rollers, NOT alcohol as that will dry out the material the rollers are made of. Although the problem has recurred a couple of times, it's worth repeating when necessary. I actually activate the 'print' command so it tries to feed in paper, while I FIRMLY hold a piece of fine cotton cloth stretched over a thin plastic ruler, which I hold down where the paper feed grabs its paper. The printer has a couple of tries to feed paper, reports an error message (because there was no paper) and I activate it again, thus exposing the WHOLE of the feed wheel to the cleansing cloth! WORTH A TRY!
EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
Take all the paper out,Make sure non of the paper is folded under on the stack. check the paper-feed area for debris,(papreclips, staples post it notes etc).
Check the tray and its guides are secure and it the correct positions.
Open the machine check the paper path for debris, bits of paper or anything the looks out of place.
Once you have checked and cleared everything, close uo the machine and try again.
If you are inclined, you can clean the paper rollers with alcohol.
Hope this is of some help
Ed
3answers
Error Message
Please check connecting cables with PC.
Unplug printer form AC outlet for couple of minutes and replug back in and check.
1helpful
2answers
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
4helpful
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Problem printing - Epson stylus photo 895
1 bring out the catridge of the printer to clean and make sure the ink flow during the cleaning.
2 insert and reset the catridge.
2answers
Epson RX520 feed problem when using glossy photo paper
clean the rubber rollers that pull the paper. hoping it 2 work fine....
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
