Question about Bausch and Lomb Optics
Broken eyepiece, 1940s vintage 7x50 individual focus binocular. Need hard rubber or bakelite replacements. eyepiece threads onto brass adapter ring (1 3/16in outside, 7/8in inside)
    New Friend:
  • 43 Answers
Here in Melbourne, Australia I make these for people who need them. I also have a reasonable amount of stock generic ones. The question is not so much the size of the ring, but the thread size, the depth of the eyecup (depends upon the magnification) which sets your eye at the correct distance behind the eyepiece (eye relief) and the size of the central hole to suit the size of the eye lens. There would be other small engineering companies that could make one for you out of delrin.
Posted on Mar 03, 2010
6ya staff
SOURCE:
I see double image unless I take the lens as close as the binoculars can go
thats how binoculars are. Yours in this case is really strong. the closer you are to something, looking at it, the more magiflyed you going to be. try view things far a distance, really far away. no more double right?
Everything you need to know to become an expert:
on this website: http://www.chuckhawks.com/binocular_basics.htm
It is surprising how many people do not know how to focus binoculars correctly. There are two common focusing systems used in binoculars.
The first is individual eyepiece focus. This system is simple to understand, and easy to manufacture. It also lends itself well to sealed optical tubes, and thus is usually the focusing system used for waterproof binoculars. Individual eyepiece focus means that to focus the binoculars to your eyes, you simply focus the left eyepiece to your left eye and the right eyepiece to your right eye. There is no centrally located focusing mechanism. It is done like this. Look at something in the distance. Close the right eye (or cover the front of the right binocular), and focus the left eyepiece to your left eye. Close the left eye (or cover the front of the left binocular), and focus the right eyepiece to your right eye. You are finished, until you need to look at something at a different distance, in which case you need to repeat the process.
Because individual eyepiece focus is time-consuming, center focus is more common. Unfortunately, very few people understand how to correctly use center focus binoculars. Here is how it is done. Aim your binoculars at something in the distance. Close the right eye (or cover the front of the right tube), and focus the left side of the binocular to your left eye using the center focus control, which is concentric with the pivot shaft between the binoculars. (Note: the left eyepiece itself does not focus on center focus binoculars.) Next, close your left eye (or cover the front of the left tube), and focus the right eyepiece to your right eye. DO NOT touch the center focus control while you are focusing the right eyepiece to your right eye. Now you are finished. What you have just done is adjust the binoculars for your individual eyes. (Practically everybody's left and right eyes are different.) From now on, you only need to adjust the center focus control when you look at things at different distances. Center focus is faster and easier to use than individual eyepiece focus, once you have initially set the binoculars for your eyes.
Binoculars are commonly described by using a pair of numbers, as in "7x50" or "8x25." The first of these numbers refers to the magnification offered by the binocular. Magnification is why most people buy a pair of binoculars. In the examples above, "7x" means the binocular makes whatever you look at appear seven times closer than it does to the unaided human eye. "8x" means the binocular makes whatever you look at eight times closer than the unaided human eye. "10x" makes things look ten times closer, and so on. The first number used to describe binoculars always refers to their magnification. Common binocular magnifications are 6x, 7x, 8x, 9x, and 10x.
There are also variable power (zoom) binoculars, such as 7-21x50. These almost always perform much better at the low power setting than they do at the higher settings. This is natural, since the front objective cannot enlarge to let in more light as the power is increased, so the view gets dimmer. At 7x, the 50mm front objective provides a 7.1mm exit pupil, but at 21x, the same front objective provides only a 2.38mm exit pupil. Also, the optical quality of a zoom binocular at any given power is inferior to that of a fixed power binocular of that power. In general, zoom binoculars are not the bargain they seem to be.
Remember that everything (including movement) is magnified when you look through a pair of binoculars, especially your own shakes and tremors. So the higher the power, the harder it seems to hold the binoculars steady. 6, 7, or 8 power binoculars are easier for most people, even those with very steady hands, to hold reasonably still. The higher powers sound like a good deal, but often result in jiggly, blurred views. This is why 7x binoculars are chosen by so many experts, including the military.
Power affects brightness. Other things being equal, the higher the power, the dimmer the view. And power also affects the field of view of the binoculars. Again, everything being equal, the higher the power, the smaller the field of view. So, as you can see, power must be balanced against other desirable characteristics when choosing binoculars.
May 09, 2011 | Bushnell 240842 Binocular
My USN WWII individual focus 7x50 oculars were hard to turn. I turned too hard. Now one unscrews all the way out. Can it be fixed?
the grease has turned hard and they need to be regreased and recollimated...best bet is to do a complete overhaul at this point......larry@reichinstrunents.com
Mar 29, 2011 | Optics
Right & left eye does not focus together. They appear to be @ two different powers
Your binoculars either have a bent or broken yoke assembly (the bit which carries the eyepieces) or one or more prisms have came unseated.
The first repair involves replacing the entire yoke assembly: the part is expensive in comparison to the retail cost of a new pair of binoculars and with labour charges on top is not usually a cost-effective repair except on really high end models at prices far higher than yours which can be completely replaced for under GBP£115.
The second repair is straightforward and fairly quick for anyone with the right collimation equipment, but the screw(s) need to be secured with thread-locking liquid afterwards.
I hope you manage to use this information to fix your binoculars or at least that it assists you to choose your next course of action. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Sep 28, 2010 | Nikon Action Extreme 7x50 Binocular
Where can I get replacment eyecups for Zeiss 8x56 binoculars.
You'll need to measure your eyepiece in "mm". Also determine if your eyepiece has an outer ring the eyepiece will slip over. You can find eyecups/guards on Ebay. Search under Binocular Eyecup or Binocular Eye Guard. There are also eyecups under "rubber eyecups/rubber eyeguards" but alot of these are for Microscopes and may not fit. You will need to pay close attention to the mounting type and measurements.
Mar 18, 2010 | Optics
One side won't focas
You don't say what model binoculars you have, but there are two possibilities (well, three, but the third one is that your binocs are broken - lets try the other two first!)
Some very fine binoculars have individual focusing for each eyepiece. You focus each side for your eyesight. If that's the case with your binoculars, there won't be a central focusing control.
If you DO have a central focus knob, it's possible that your binoculars have a "diopter" focus on one or the other eyepiece. Look at the rim of the eyepiece for a marking that looks like "+ . . . | . . . -" or something similar. What you want to do is focus the binocs using the central control so the the UNMARKED eyepiece is in focus for you (close one eye to focus), then switch eyes and focus the marked eyepiece by rotating the eyepiece rim until both eyes have good focus.
Binocular manufacturers do this because many people have better vision in one eye than the other, and many people also prefer to use binoculars without their glasses. Hope this helps.
Oct 07, 2009 | Barska Optics Optics
Replacement parts for Tasco binoculars
Sep 18, 2009 | Tasco Wide Angle and Rubber 2023 (10x50MM)...
I bought these for my husband. In trying them
Difficult to answer specifically without knowing the model. But binoculars are designed to view objects in the distance. They all have a limit as to how close they will focus based on the magnification and design. Objective lenses that are far apart such as on a porro prism binocular will not focus very close. The nature of the design of having the objectives further apart than the eyepieces doesn't allow it. When trying to focus too close the image will appear blurred and double. That is the nature of the design. 9 feet or 3 metres is considered quite close to focus a binocular and is usually for a model designed to do this such as a roof prism where the objective lens and the eye lenses are inline. A specialty binocular such as the Pentax Papilo will close focus to 50 centimeters. It has been designed so that the objective (large lenses) lenses converge.
Take into account when focusing that binoculars are also designed to compensate for differences in each eye. One of the eyepieces either right or left will adjust seperately. For binoculars with a center focus ring. First focus using the center ring with one eye covered. The eye that should be covered is the one that doesn't have the adjusting eyepiece. When the image is clear close the eye you have just used and leave the center focus alone. Focusing on the same spot look through the eyepiece that adjusts and turn the eyepiece ring until the image is clear. Now all you have to do is focus using the center ring only as the binoculars are adjusted for each eye.
Some binoculars do not have a center focus and each eye will adjust seperately.
Jul 29, 2009 | Optics
My Tasco model 440, 7 x 50 binoculars, 1980 vintage needs new eyecups. Where can I find replacements. Bill
Jul 11, 2009 | Tasco Sonoma& 8 x 40 Wide Angle Zip& Focus...
Differnt focus for each eye?
All binoculars (except some really cheap rubbish) have a different focus for each eye. There are two types. Binoculars that have two individual eyepieces that turn and no center focus wheel. This is common to military, astronomy and binoculars used at sea.
The other is the usual center focus binoculars that have a wheel between the two barrels. They will also allow either the left or right eyepiece to turn to focus for one eye. The reason is that manufacturers take into account that each eye is slightly different.
Jul 04, 2009 | Optics
Bushnell insta-focus mechanism gets stuck.
they were famous for that, because the screwpin that holds the eyepice shaft is metal and the groove that it rides in is plastic, and eventually gets jammed....look where you put your fingers to adjust eyepieces. should be small metal plate in center of hinge(sometimes with bushnell logo) that will simply pry off by using small screw driver,and now you will be able to see if the screw is loose or damaged. good luck...larry@reichinstruments.com
Jan 14, 2009 | Bushnell "Insta-Focus" Binoculars
Optics Logo
299 people viewed this question
Top Bausch and Lomb Optics Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
M J U
Level 1 Expert
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
