2000 Ford Taurus Logo
Posted on Jan 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for diagram of serpentine belt - 2000 Ford Taurus
Anonymous
Level 2:
Scholar:
  • Expert 65 Answers
  • Posted on Jan 16, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
65
Questions
0
Helped
33772
Points
214
looking for diagram of serpentine belt - 0996b43f80208ca1.jpg enlarge_ilooking for diagram of serpentine belt - enlarge_tooltip.gifienlarge_tooltip.gif Fig. Serpentine accessory drilooking for diagram of serpentine belt - 0996b43f80208ca2.jpg (VIN U) engine
0996b43f80208ca2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-3.0L (VIN S) engine
0996b43f80208ca1.jpg enlarge_tooltip.gif Fig. Serpentine accessory drive belt routing-Ford 3.0L (VIN U) engines
0996b43f8looking for diagram of serpentine belt - enlarge_icon.gifss= enlarge_icon.gifenlarge_tooltip.gif Fig. Serpentine accessory drive blooking for diagram of serpentine belt - enlarge_icon.gif 3.0L (VIN S) engine
enlarge_icon.gifenlarlooking for diagram of serpentine belt - enlarge_tooltip.gifss= Fig. Serpentine accessory drive belt routing-Ford 3.4L SHO engine
0996b43f80208ca0.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Water pump drive belt routing-Ford 3.4L SHO engine
i wasnt sure what engine you had hope this helps good luck
5 Related Answers
Zach Walker
  • 13 Answers
  • Posted on Jun 16, 2008
SOURCE: serpentine belt diagram:
if yours has the 3.8L then here is the diagram. Hope this helps
~ Zach
Anonymous
  • Posted on Jul 18, 2008
SOURCE: 1993 DODGE CARAVAN SERPENTINE BELT DIAGRAM
Look on the top radiator cross member by the hood latch- the belt routing diagram should be there. If not, the same engine and accessory configuration was used on all Chrysler, Dodge, and Plymouth minivans through, at least, l999. If you can find any of those with the 3.3liter engine, the diagram should be located where I said. Good luck
Anonymous
The belt routing diagram is located on the top radiator cross member by the hood latch. You should see it when you open the hood. If it is not there, all Chrysler, Dodge, and Plymouth minivans, from 1993 to at least 1999, used the same 3.3L engine setup, so find someone with one and look for the diagram where I described.
Anonymous
  • Posted on Aug 02, 2008
SOURCE: 2003 Jetta tdi serpentine belt
I am looking for a diagram of the timing belt alinement for a 2003 Jetta tdi 1.9
autodr
autodr
  • 260 Answers
  • Posted on Nov 18, 2008
SOURCE: serpentine belt diagrams
8d144a3.gifhope this helps
2answers
1997 dodge Dakota sport serpentine belt diagram
https://www.justanswer.com/dodge/0xzkw-looking-serpentine-belt-routing-1997-dodge-dakota.html
A diagram for 1997 Mercedes Benz serpentine belt diagram diagram for a 1997 Mercedes Benz serpentine belt diagram series 280
if you look under your hood, on your radiator top support, there should be a diagram there, or on the under side of your hood, look around under your hood, all cars have this diagram posted somewhere
Remove the serpentine drive belt.
Loosen the Tensioner and make sure you memorize the Routing of the Belt.You did not give a year make model but many are on-line if you look. Put your Year/Make/Model and then serpendine Belt Diagram
ie..
99 Taurus Serpentine Belt Diagram and then search.
7helpful
2answers
Need diagram of drive belt assembly forcaddy
You didn't list your motor size so please pick the applicable diagram:
Accessory serpentine belt routing—4.8L, 5.3L & 6.0L engines
Accessory serpentine belt routing—5.7L engines with A/C
Accessory serpentine belt routing—5.7L engines without A/C
Accessory serpentine belt routing—6.5L Diesel engines
Accessory serpentine belt routing—7.4L engines
Accessory serpentine belt routing—8.1L engines
2helpful
Need to replace a serpentine belt in a 2000 mitsubishi eclipse
You should be able to see the diagram for the serpentine belt when you open the hood.
3helpful
2answers
Serpentine belt diagram
The serpentine belt routing should be labeled on your radiator shroud. Look around the engine compartment like the hood or radiator fram suport and there should be a label with the the belt routing.
Good luck and hope this helps
2helpful
2answers
Serpentine belt diagram:
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
