Make sure you have installed the scanner drivers for win7. I have the same printer and I can print & scan from Win XP, Win 7 & my iPad (All on wireless). Drivers for the printer & scanner must be installed.
Disconnect the printer from the PC, and delete the printer you have installed & remove all the software previously installed on the PC. Reinstall the download "Drivers & Software".
In installing the Lexmark x1270 drivers, you have to install the correct drivers for your Operating System(OS) ie. for Windows OS. Depending on your Windows OS ie (x86 or x64- 32bit or 64bit) WinXP, Vista or Win7. (Mac is not support)
Link to download your needed drivers for your Windows OS versions @ Lexmark Support .
Select your Windows versions to download the drivers.
The problem is with driver signing. 32bit drivers don't always (usuall) work with 64bit OS. It's up to the hardware manufacturer to update the driver.
I did some research and found this link. One guy said the fourth solution worked for him: http://www.freeotfe.org/docs/Main/impact_of_kernel_driver_signing.htm#Method_3
OS Provided Microsoft Windows XP Media
Center Edition 2005 ----thats the original os of your pc the problem is its in 32bit you jump to win7 ultimate w/ 64 bit what i can suggest to that is re install win7 however look for the win7 32bit installer or download a driver win7 for a pc net 32 bit.
OK, at the link below you will be able to download the latest driver for this printer. Just remember to choose the operating system you are using before you download the driver(32bit/64Bit).
*This motherboard dont have a driver for Windows 7 however you can download the Windows Vista driver for you Windows 7, If youre using Win7 32bit download WindowsVista 32bit for Win7 64bit use Vista 64bit.
Hello sir, hi, installing a USB device on windows 98 is kinda hard but possible. here are some things that you should do:
you may need the sierra CD device driver that comes with your wireless card.
next is that your PC should support USB 1.1 or 2.0. If you are using windows 98, make sure that your USB port is working fine, you can insert a flash drive to confirm if your usb port is working.
depending on the setup files they may need you to plug in the device as the setup file loads the driver or later.
run the sierra CD setup file to install your wireless card. (hope win 98 supports this device)
after the setup, plug in your wireless USB device, windows 98 should detect it.
If things didnt work out as listed above, do it setup several times, ............ still no progress call your dealer for proper installation on your PC.
