My Sigma 70-300mm lens ''defaults'' to manual focus when I attach it to my Pentax istD.S digital camera. I cant get it to operate on auto focus althought the camera setting is on AF
Hi
if you can turn the iris ring you must set it to the A it has a lock bunton
you must press to put it in the A this may fix it
It will default to manual through the viewing screen. It will only work on automatic, using the viewfinder. Make sure you also set the focal length (lens to shutter distance). You might also have a mf / af switch on the lens. This also only works through the viewfinder.
