Washing Machines Logo
Posted on Jan 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Indesit wie 147 F-12 - Indesit Washing Machines
Barry Coates
Level 3:
  • Indesit Master 3,463 Answers
  • Posted on Jan 16, 2010
Barry Coates
Indesit Master
Level 3:
Answers
3463
Questions
Helped
1406746
Points
12766
F12 indicates a communication error between boards.
Check all connections to the boards.
Why does my indesit WIE 107 display f04
the pressure switch is jammed on empty. this could be either a faulty pressure switch, blocked pressure hose (pull off small hose and blow down to clear any debris) or a blocked sump hose ( big black hose at the bottom of appliance)
10helpful
3answers
Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Washing machine
Sure you can. Click on "Indesit" or "washing machines" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Indesit machine won't start
on the bottom of the machine there is a panel made of plastic that may be removed to expose the waste filter.open the waste filter and check that the waste pump is not blocked as in the initial start up the pump is run if there is a problem with the pump the machine will not advance.
Top Indesit Washing Machines Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Sean Wright
Sean Wright
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
