How to switch the camera over to saving pictures directly onto the SD card.
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Answer :
Follow these steps:
SOURCE: Just put 2gb sd card
on a kodak you can also copy your internal photos to card-go to menu and find menu highlight that says storage or something like that and change setting to use card first-when the camera has a card in it it will usuallt default to card first
SOURCE: Internal Memory Full??
The Internal memory and SD card are different beasts. There is a certain value that alows pics to be taken without a memory card in situe. It is this part that is saying the memory is full Use settings to clear internal meory of photos or files being held. If this oersists even after yoiu have emptied the memory you will need to take it to a Kodak outlet
SOURCE: I put a new memory card in the camera and it says
You need to eliminate the pics from the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and do the "format" thing again for the card. Everything should be normal now.
SOURCE: Camera keeps saying internal memory is full, even after putting a
Your internal memory is separate from your memory card. Think of it as two folders, the internal memory cannot be removed, and the memory card is one you can take with you. You can put new memory cards in it all day, the internal memory will still have pictures in it. You may wish to consider copying all internal memory to the memory card. To do this, make sure your camera has a memory card in it. View pictures on your internal memory, then from the menu option select 'copy all images to external memory.' In doing this, all of your photos will be moved, you can then clean out your internal memory by deleting everything/formatting it. :)
SOURCE: CAMERA SAYS INTERNAL MEMORY FULL.
The internal memory is the memory built into the camera, not the memory you put in with a memory card. This internal memory is rather small. If it is completely full, it will stop your camera working even with an empty memory card.
Take the card out of the camera, and delete some of the photos on the internal memory before you put it back in.
