To make a sound continue through multiple or all slides, follow these steps:
Now you can play the soundtrack from the very beginning to the end of your slideshow.
Source:
http://www.dvd-ppt-slideshow.com/powerpoint-knowledge/sound-across-slides.html
The PowerPoint software program allows you to create slide presentations that can be viewed on any computer.
While some graphic artists specialize in developing compelling presentations, anyone can develop a PowerPoint slide presentation that is attractive and readable.
Follow these steps to develop your own slide show.
Open your PowerPoint program. When the dialog box opens, click on the "Blank Presentation" option.
Choose an "AutoLayout" format.
Begin with the title slide layout, which is the first one on the left. Click "OK," and you will have a title slide to work with.
Add text to your slide by clicking in the title text box and typing a title.
Do the same thing in the subtitle box.
Create another slide by clicking the "New Slide" button on the Common Tasks toolbar.
When the AutoLayout dialog box appears, choose a layout for this slide.
Keep adding new slides until your presentation is complete.
Move from slide to slide by clicking the button on the lower-right corner of the PowerPoint window.
Clicking the button with the upward-pointing arrows will take you to the previous slide, and clicking the button with the downward-pointing arrows will take you to the next slide.
Save your presentation. Click the "File" menu and then click "Save As."
A dialog box will appear, and you'll be able to type in a name for your presentation.
The presentation will be saved to your hard drive.
as for the kreb cycle disgram im not sure
hope this helps
Find links to information about saving presentations in the See Also section.
If you choose this option, you cannot use any of the features that are new in Office PowerPoint 2007.
The new slide now appears both on the Slides tab, where it is highlighted as the current slide, and in the Slide pane. Repeat this procedure for each new slide that you want to add.
Tip If you want your new slide to have the same layout that the preceding slide has, you can just click New Slide instead of clicking the arrow next to it.
The Broadcast Slide Show dialog box opens.
Note If you do not see the service that you want to use, select Add a new service, and then in the Add Broadcast Service dialog box, enter the network address of the service you want to use and then click Add.
PowerPoint creates a unique URL for your slide show.
The audience follows your slide show in their browser while you present within PowerPoint 2010.
After you begin broadcasting a slide show, the Broadcast tab appears in the PowerPoint 2010 ribbon.
Regards,
Tech_Comp
